Sometimes the glow plugs are not functioning, light not showing, engine not starting....... not even in this weather
A poke with a screwdriver where the wire connects to the first plug and a tap on the relay box seems to temporarilly remind it who's boss but then weeks or months down the line it happens again
What's a fulltime (cheap) solution?
GLow plugs?
GLow plugs?
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
If the glowplug warning lamp isnt lighting up this could be one of two things - power to the heater plug relay isnt getting there or the timer relay itself is worn.
As it seems to work when you give it a prod, I would suspect a poor connection - the soloution to renew and see if that helps.
Otherwise try another relay and see if its any better.#
Oh yes, forgot to mention, it could be a worn ignition switch, but I would go for dodgey connection at the relay first.
Ta Marty, will check it out .... also have a wandering accelerator pedal to remedy before selling the old girl for a pittance
'94 XM 2.1TD Break
'94 XM 2.1TD Break
From the battery plus pole - you havethis weird huge spade connector distributor plug. This is known to play up. I've tried sort out this on one of my BX'es. The only remedy to finally sort it out - was a new battery pole clamp connecting all the wires to the battery.
That spade connector distributor - is a direct invitation to problems somewhere over time ...
Don't think you need it but look what I've found.
http://www.screwfix.com/app/sfd/sea/sea ... er&x=0&y=0
- sleepy0905
Cheers Sleepy but problem sorted (bad connection) and the car is with it's new owner
'94 XM 2.1TD Break
'94 XM 2.1TD Break
- sleepy0905
