TD engine from Poogo 405 into N/A BX?
ed4ferrets
Post by ed4ferrets »
Saw this ad and wondered how much of a headache it is to convert and transplant, also is the gearbox compatible? :-k
PEUGEOT 405 TD Estate, L reg, 95k, needs new clutch, MOT end Aug, genuine giveawayPEUGEOT 405 TD Estate, L reg, 95k, needs new clutch, MOT end Aug, genuine giveaway
Keeper of the site Goat
Post by cavmad »
How long is the MOT and is it a genuine giveaway? :lol:
Vauxhall apologist.
ed4ferrets
as it says on the tin mate ..... free to collector!! :wink:
I still hanker after the TD extra performance for when it's needed but in estate form, a windfall like DLM's estate would have been nice but transplant surgery may be my only option. At 95k the engine has just about been run in (assuming it's kosher) but I would like to find out more of the practicality of the pipedream project.
eeeer, should this post be under technical rather than chat perhaps? :?
We can make it fit! My engine cranes been on part time hours lately.....
Time for it to have some excercise :D
Chris G
The 405 gearboxes need modding if you run a HP pump the runs off the cam....the main control linkage into the box is at a different angle to a BX one, it either needs changing over or blow torching til its red hot, smacking with a big hammer and bending with a pair of Stilsons.
Jobbed!
ed4ferrets
:-k methinks me should see if this motor is still available, and if so get Jon and Chris to convince SWMBO of it's merits :wink:
I can usually persuade female types anythings a good idea!
If my enigmatic charm doesn't work the shovel usually does!!! :shock: :D :D :D :D :D :D :D
Chris G
