Black interior
sleepy0905
Black interior
Post by sleepy0905 »
Due to a change in circumstances Does anyone want a black dashboard, steering wheels and the A,B, trims plus all the other bits of plastic and carpets free of charge needs to go asap or it will end up in the tip
tim leech
Post by tim leech »
If it helps I can pick these up and bring them to burton upon trent and you can collect them from there. Will be at the CCC on the 17th so can bring them along.
x 82
what condition is the dashboard in? Not really keen to have it out again, but the bit by the window is deffinately cracked on mine :(
sleepy0905
the dash is fine it has a mark from the fag lighter but thats all it came out of billys estate all the trims are there except the c pillar and boot ones.
x 82
Ah, that dash is in slightly worse condition than mine so best stick with what i have!
However, i've just realised how much i need the rear carpets! Mine got covered in PU glue and made a horrid mess, simply covered over it with mats!
Actually my front carpets are out of shape on the drivers side and the o/s c'pillar trim has a piece missing and both a pillar trims have holes!
Think i better take the lot bar the dash if there still on offer? Are you coming to stratford? Might have them from you then if possible?
sleepy0905
you can have the lot vanny I wont be at stratford infact i wont be going far for a while too much to sort out .
Come on someone who want a black dashboard.
tim leech
Post by tim leech »
Vanny i can pick them up for you saturday night when i collect the sunbed, and can meet you at stratford in the afternoon where you can pick them up from me?
x 82
Sounds like a plan Mr Leech, thank you very mcuh!
I'll be at Stratford all weekend so you shouldn't miss me!
PS Do you have my Citroen flag tim? Mr Fearn seems to think it went home with you?
tim leech
Post by tim leech »
So thats whose it is then! Ok will return at stratford!
sleepy0905
interior now gone thanks
djoptix
Post by djoptix »
If the dash is still around I need the panel that runs across behind the windscreen (ie the bit with the heater vents in)...
sleepy0905
sorry but all the interior is gone.
Thanks
x 82
djoptix wrote:If the dash is still around I need the panel that runs across behind the windscreen (ie the bit with the heater vents in)...
that would be the bit that always cracks! And more over, its plastic welded to the rest of the dash so you cant just swap it :( Soooooo not fair cos mine cracked up last month! :(
djoptix
Post by djoptix »
Doh! Mine has a small crack, barely noticeable, but it's right in front of the driver :twisted:
djoptix wrote:Doh! Mine has a small crack, barely noticeable, but it's right in front of the driver :twisted:
Same :lol:
