1990 BX 16 valve *UPDATED*
Kitch wrote:The other one is the little green placcy T-piece on the resevoir cap has broken. Hasn't really leaked anything that I can see, but its worth mentioning
mmm....... could do with one of those too. I repaired mine twice with mini Ty-raps but it always broke again in another place as the plastic obviously goes brittle with age. :cry:
edited all to photobucket album
And a nudge too :lol:
Post by jeremy »
The problem seems to be that the 2 clear plastic pipes pull tight and wreck the plastic 'T'piece.
The backward one goes into the inner wing and presumably the plastic liner moves and pulls it tight.
Re-routing the pipe may save the life of the 'T' piece.
If pushed I suppose you could make a substitute using a washer 'T' and some fuel tube as joiners.
Sold!
x 103
You could just tell us rather than make us beg!
jeremy wrote:The problem seems to be that the 2 clear plastic pipes pull tight and wreck the plastic 'T'piece.
I think it's more that the curve of the two clear pipes go above the bonnet line and the bonnet smacks them each time it closes. :cry:
I think it's just old age. They go hard and crack, buy a new one and you'll see how very supple they are! old ones are like rock.....
So Kitch, anyone we know?? Or is it all a bit cloak and dagger?? :wink:
Chris G
Keeper of the site Goat
Post by cavmad »
Nice one Kitch, a good home too.
Vauxhall apologist.
