Bosch......
- Backslash Bandit
- My Cars: Cars
- x 3
Bosch......
Does anyone have a TD with bosch pump? If so, or if anyone is in the know, what is the length of movement on the timing advance device found on the front of the pump?
Mine doesn't move at all but if I leave it disconnected, it coughs on start up. If I connect it to advance timing to avoid coughing, the timing stays advanced which I assume is not ideal????
The actual lever has a travel of about 25mm but I cant see the device moving that much, in which case, which is the correct position for this lever when hot/when cold?
- Backslash Bandit
- My Cars: Cars
- x 3
Thanks cauchoiskev, is that definitely the timing advance rather than the cold start accelerator which just picks the revs up until hot. That too moves by approx 6mm. I don't mean to sound pedantic but the two seem to be often confused.
Hi This I realise is not much help but my unit has not worked as long as I have had it, I have tried holding it off the stop but it does not seem to do anything. The lever on the back of the pump was adjusted for tickover and locked off as this didnt work either. If it's very cold then a little throttle at start, otherwise thats, it no problems.
Cheers.
Geoff.
Cheers.
Geoff.
1991 BX 1-7 td Auto.
NEVER WRONG.
NEVER WRONG.
- Backslash Bandit
- My Cars: Cars
- x 3
I'm a stickler for all things mechanical to work properly - it really bugs me There don't seem to be many people who have the Bosch pump who can shed light on this device. I am considering replacing it with a solenoid which I think will be simple enough but its making sure I buy the right solenoid to fullfill the purpose properly.
As Chris said when I spoke to him about this when he came over the water, these type of devices only travel a few mm.
If I disconnect the thing altogether, the car is a complete bu**er to start, and needs about 4 attempts before it finally runs and clears the coughing fit.
Which lever do you mean Geoff?
- Backslash Bandit
- My Cars: Cars
- x 3
Tickover is about 850 its not the waxstat though, the one which fits in the thermostat housing. This brings in a faster idle until the engine is warm. That works as it should.
The device I'm having trouble with is fitted on the front side and to the right of the fuel pump (mounted on bracket bolted onto right hand end of pump)when looking into the engine bay. It has its own coolant feed and works on the same principal as the waxstat (expansion when hot) to advance the timing until the engine is sufficiently hot. (I think the rotodeisel did this via a small electrovalve or solenoid which was operated by the thermostat waxstat).
So, it doesn't affect revs, just timing when cold. Without it, the car is difficult to start and with it connected to give cough free start, it's not easing off when hot. So my concern is running the engine with the timing permanently advanced and what damage this may do to the engine long term (or possibly performance/consumption side effects)
Lever.
Hello BX Bandit Sorry mate I may have been a little misleading when I said the lever on the back of the pump as it is actually on the side of pump facing the block. It's the one that is worked by the waxstat on the thermostat housing. I have never yet had one that worked consistently, so I slacken off the cable, set the tickover when its hot and lock the lever with the two set screws, so that it cant move. If it effected the starting at all then I would have replaced it. Because the thing held the tickover fast sometimes it did two things, used extra fuel and made it a bit awkward as it is a automatic. The long lever on the front of the pump does not appear to alter anything, there is no problem starting, it does not miss or stumble.or smoke if it comes to that.
It is not a new engine by any means as it uses the old hex. head bolts.
Cheers.
Geoff.
I will try to be more accurate next time. I do apreciate the matter of things that should be right.
Cheers.
Geoff.
NEVER WRONG.
NEVER WRONG.
There are more Bosch pumps without the lecer than with! Later pumps had electrovalves. The idea is indeed to alter the pump timing when the engine is cold, however if the lever cant be made to work properly you can disconnect it completely and just advance the static pump timing by a very, very small degree and it should start fine even on the coldest mornings and have bu&&er all effect (adverse) when hot.
Chris G
Chris G
- Backslash Bandit
- My Cars: Cars
- x 3
erm whats lecer I assume then the electrovalve would be a straight swap...but from what car ?There are more Bosch pumps without the lecer than with!
I like the idea if turning the pump a wee bit but why didn't Citroen/Bosch do this instead of faffing about with this silly device?
Swapped a bosch pump on my mates Xantia last weekend, the original pump had a device on the front with a wire attached to something that resembles a stop solenoid, the other end of the blob has some steel pipe coming off and going into pump body? replacement pump was otherwise identical but did not have this, it runs fine
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
- Backslash Bandit
- My Cars: Cars
- x 3
Thanks oily, that sounds like a solenoid I suppose. Could you get a photo and email me, I'll see if it might work on mine. Is it available for some tokens?? I'm coming to the conclusion that I may just do as Doc suggested, I've never checked the timing as it came off a donor car and seemed ok. The other thing to do is rig up a bolt or studding and adjust until it runs ok.
Thats the fella! It replaced the mechanical arm setup. IIRC David Rutherford is a bit of an expert on these things.....Stewart (oily!) wrote: the original pump had a device on the front with a wire attached to something that resembles a stop solenoid, the other end of the blob has some steel pipe coming off and going into pump body?
Stewart
Chris G
