Ta Muchly!
WINGNUT
tom
- Citroen Sorceror
- x 94
Std 10mm nut and a ratchet spanner
Kitch tip of the day:
Or.....go down the scrappy and find and AX or Saxo. As standard, the rear lamps on these cars are held on by the same wingnuts. Open the boot and have a nose at the light fixings. Two on each lamp on AX's, and one on each lamp on Saxo's/106's.
Probably applies to 106's too.
BX 16v Ph2 - XPO - x 103
- Keeper of the site Goat
Vanny wrote:You'll want them to be plastic so you have half a hope of getting them back off again!
Kitch, your a ____ genious! And absolutley right, though i never made the link myself! I suppose than that 405 rear light clusters will have the same (where they dont just have plain nuts!)
Vauxhall apologist.
you spend 8 hours in the library for the last 8 days and still be sane! Found myself flicking through 'Knots 96' today, riveting.
And, that is three spelling mistakes NOT grammar, and you missed one too, some teacher you would make. You just wanted to show off your new picture didn't you William, well go to the front of the class for being clever
Vanny wrote:you spend 8 hours in the library for the last 8 days and still be sane! Found myself flicking through 'Knots 96' today, riveting.
Sorry Vanny, you`re quite correct of course. Just coudn`t help myself!
Vauxhall apologist.
tim leech
- x 94
- x 94
