Brand New. Air con Condensor BX 16V
bernie
Likes welding rusty Fiats.
Post by bernie »
Cost me £135 a year ago and probably the last one in the world. :shock: :shock: :shock: :shock:
£125
50 posts, now I must go and have a widdle :oops:
Just the 0 BX
1 TZD Turbo a/c going going GONE
1 TD Hurricane being broken up for spares
3 FIAT 124 Sports!!!
1 FIAT 124 Spider ex. California
Oh and I nearly forgot
A LOVELY XANTIA HDI EXCLUSIVE ESTATE
Ooooh, still tempted - it looks sooo nice and shiny in the picture.
But no, must RESIST and spend the money on more important things like food :)
bernie
Post by bernie »
30 deg. outside :D
Sun beating down :)
Stuck in a traffic jam :(
NO AIR CON :x
But you have food :cry:
Just the 0 BX
Would it fir a GTi 8v with AC?
I MEANT FIT
bernie
Post by bernie »
Philip chidlow wrote:Would it fir a GTi 8v with AC?
Do you have A/C fitted at present?
Just the 0 BX
bernie
Post by bernie »
Go on Mat you know you want it :wink:
Just the 0 BX
AlanS
Post by AlanS »
Just a bit of added info on this; here in Oz I understand they are still available (which is logical see as how all 16Vs here were air/conned) but will cost you in the vicinity of A$2000 which tells you either:
(a) This one's cheap.
(b) We're getting ripped off over here.
(c) Somebody's gunna wish they'd bought it when they had the chance
(d) Bernie's gunna wish he'd never sold it.
As regards its interchangeability; the Condensor on an 8V version sits in front of the radiator but behind the front upper crossmember.
The 16V model due to the extra room taken up with head and intake plenum is forced to sit in front of the same crossmember with the result that the physical surface area is much greater on the 8V version so as a result, it would be great dramas to retrofit a 16V condensor to an 8V car. Not impossibly probably but not very feasible and for the record, the 8V air con is much more efficient than that on the 16V possibly for this very reason.
Alan S
bernie wrote:Go on Mat you know you want it :wink:
Stop it; you are being a bad influence :)
Whoops not sure what happened there...
bernie
Post by bernie »
AlanS wrote:Just a bit of added info on this; here in Oz I understand they are still available (which is logical see as how all 16Vs here were air/conned) but will cost you in the vicinity of A$2000 which tells you either:
Alan S
WOW!!!!
That £847.33 :shock:
I'm sitting on a goldmine :D
It would be a bargain in Austrailia even including P+P :wink:
Thanks Alan
Just the 0 BX
bernie
Post by bernie »
Price could rise soon :shock:
Just the 0 BX
bernie
Post by bernie »
Perhaps Alan, I could sent it to you or you know of someone in Austrailia that wants one?
Just the 0 BX
