Anyone know where that leads? And how difficult it will be to replace if (horror of horrors) I do it properly rather than bodging it up?I wrote:I did something today that I'd never done before - I polished my car. And re-applied the bumper treatment (from Meguiars, no less). It was looking great, and a nice chap from up the road chatted with me for a bit, passing the time and reminiscing about nice old cars. When he left, he asked me if I knew I was losing oil and pointed to the front bumper. Oh. Damn.
Well, that definitely wasn't there when I was treating the bumpers - which I'd done with the car up high, to make it easier to reach the undersides and awkward bits. Maybe it was leaking when the car dropped - which I'd done to polish the roof. A bit of experimenting and I found the leak.
I raised and lowered the car and tried to capture the LHM peeing out - it goes with enough pressure to water the radiator - but didn't manage to take the picture quickly enough before it stopped. See the Y-shaped pipe? The leaking pipe is the left-hand one. Of course, the leak is in the pipe that runs towards the back of the engine bay and disappears into the bowels of the engine, not the easily-accessible one on the bottom of the fluid reservoir.
For now I'm going to snip the end and push it back on further down, but I will be trying to find out where that pipe leads, and how hard it is to replace.
I might need to think about doing something drastic like replacing the octopi if it's going to keep springing leaks at this rate.
Further leakage (with some polishing)
stuart_hedges
Posted on my website today:
DavidRutherford
- BX Digit man!
stuart_hedges
stuart_hedges
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
£55 +vat approx from citroen if its the little octopus! I managed to mend mine but I suspect that once one bit fails the rest won't be far behind. The two pipes (via the bodge) are height corrector return pipes...
stuart_hedges
DavidRutherford
- BX Digit man!
If these are height corrector pipes, then this is the BIG octopus, which is about £30. Jury is still out as to whether you have to remove the OS driveshaft to change it.
My DTR has not-long had it's octopus changed, and the bloke who did it did a rather nice little mod on it. Rather than bringing a couple of the return pipes past the cambelt cover and engine mount, they now come up and around the OS sphere, down to the tank. They had to be lengthened a bit (with bits of old octopus) but he said it was a lot easier to do that. Seems to work fine.
if you are going to do an octopus, it's a prime time to have the LHM tank out, give the whole area a clean, change the LHM etc etc.
You dont have to take the O/S shaft out, but it makes things alot easier!
For better access still, take the engine out!
Clever little mod there David, not thought of that.
*makes mental note for future use*
BX 16v Ph2 - XPO - x 103
docchevron1472 wrote:You dont have to take the O/S shaft out, but it makes things alot easier!
absolutely agree, more than possible to do without the shaft out but i like to remove it as then i can get my head right in and see whats what and inspect for any other problems! I do also have all the relevant sockets and an impact driver to do the job with so taking the DS out is a simple affair. Doing it with DS in means your simple having to go by feel a little bit more and may have to move about to see whats going on! Find a small child, they should be able to do it a little easier
DavidRutherford
- BX Digit man!
I've never yet met a woman who likes getting oily, met a few dirty ones though
As for children, pah! Nuff said...
