clutch change bx 14
simonbx17
clutch change bx 14
hi, how easy is it to change the clutch in a bx 14 as the haynes manual isn't very clear on this is done has anyone done one before.
Current.
- x 94
simonbx17
the tu
it's the TU lump gearbox on the side of the engine.
Current.
simonbx17
thanks kitch, sounds easy could a novice like be able to do one?
Current.
- x 94
simonbx17
great
great thanks kitch for your advice.
wheres the best place to get a clutch kit from?
cheers
cheers
Current.
GSF is probably your best bet, although they are available EVERYWHERE, I imagine even BOOTS have one somewhere...
Yep the TU14 BX is so simple to change a clutch in, it's almost something you can do in your lunch break. Really, they are THAT easy.
It's one of the few gearboxes I can still stick on my chest, crawl under the car with it and lift it in on my own with no mechanical assistence.
Last one I did took just over an hour start to finish. And I dont work fast.
Whereas D12 Xantia boxes......GGRRRRR.
You chose wisely my JEDI friend!!
sleepy0905
Get the clutch kit of ebay i have just bought one for my AX which has the same engine it was only £46 inc postage with a 2 year garantee from this company " japeuroparts " that was the cheapest i could find and they was very very helpfull
http://cgi.ebay.co.uk/CITROEN-AX-1-0-TO ... dZViewItem
Need to do mine as i only have 3" of clutch pedal left.
simonbx17
thank you guys yu've been most helpful know i can't wait to get started.
only drawback is i've just realised that the mot on the txd is nearly up the 20th of july
to be exact so got a few jobs to do on that one just (off topic) just need a link pipe for the exhaust and hanging bracket to be welded on any of you do welding?
thanks again
thanks again
Current.
- x 94
simonbx17
blimey, i get 10% off at gsf as i'm in the CCC.
Current.
