Yesterday it decided that it wasn't going to start no matter how much cranking I gave it. Inevitably this flattened the battery.
It looked to me as though it was losing fuel pressure when cold, but all seems OK. I had to abandon it yesterday morning and get to work in the GF's car. On getting home, I tried jump starting it off the mrs running TD fiesta, but still it wouldn't fire...Again, it sounded as though the battery was flat as the starter doesn't seem to be cranking the engine at the rate it should. In the end I got it going with easy start...last resort, but sure enough up she fired despite less than adequate cranking abilities.
I stopped and started the car with no problems after it had been running. then this morning, came out to it, and the same thing, lardy cranking, and just as I shouted my last curse she fired. SO off I went to work. My initial thinking was that it was the battery so I fitted a new one. The alternator has been tested and on full load(everything running) it's not quite hacking it. marginally under the desired output, so it's on the way out.
Strted the car leaving work and even with the new batt, it's still struggling to fire, lazy cranking all as before. Again I thought about the fuel pressure issue, but even when I had primed the system, it was still no better. I also noticed that the throttle spindle on the pump was weeping slightly, so again am thinking fuel pressure. It eventually started and got back me back home, where I tried to undo the nut securing the throttle assembly and it clean snapped the thread off the top of the spindle. Fortunately the whole lot didn't boing apart and is holding but I'm gonna need a new spindle. IS replacing the threaded spindle shaft fairly straightforward or is it a new fuel pump job? Gave up on going any further becuase I hope it can get me to work in the morning as is.
All told, well and truly pissed off with it.
Thoughts and advice on everything I've just said would be greatly appreciated chaps.
