Need to change my cambelt on my TZD
There is a lot to be said for the advice (which may come from Haynes) which is having got the belt on and timed properly and the tensioner tightened to turn the engine over a couple of times and then make sure that with the flywheel locked the bolts go in the pump and the camshaft.
On mine the most difficult part was getting the plastic covers back on!
Well it was 1 tooth out on the pump and cam, retarded too so thats why then engine sounded soft and put loads of smoke out. There is a little movement in the pulleys with the bolts in, i found that having the moved as much clock wise as possible made sure that the belt would go on in the right position.
Took a little starting as i had change the fuel filter too, after a jump from a bigger battery is jumped into life, spewing smoke out from the previous days futile running!
Tomorrow i shall do the oils and flush the rad.
Here is why its worth changing the belt at the correct intervals, mine was at its 48K mile limit, but its been 7 years since the last change, hence the poor condition -
Dont leave it too long kids!
Cheers for the assistance guys, really appreciate it!
J
J
I hope this post is still alive, apologies if im asking something already covered, its 3am and im not reading the whole post!
I ve been slowly putting back the TZD after a complete head change and waterpump change.
I put the timing belt back on after a long wrestle with the tensioner, though I was a bit concerned with the slack between the cam sproket and injector sprocket.
Once it was all back on I took out the M8 bolts from the sprokets, and the 8mm drill from the frywheel, set it in 5th, gave the wheel a spin and . . . CLUNk, no turn.
The tension between the sprokets, suddenly was fantastic but the timing is dodgy. I tried to put the pins back in. Cambelt sproket was aligned, but both the injector sproket and flywheel pin are miss aligned. . .
what now?
How can I re align the flywheel and injectors and reset the timing? Im lost on this one . . .
what now?
'91 BX MkII 1769cc Turbo TZD Break
running on RME/SVO
IF it aInt BrOKe dON't trY 'n FIx iT.
running on RME/SVO
Turn the engine a quarter of a turn (crankshaft) using a spanner on the crank pulley, probably backwards, this will leave all pistons halfway down the bores and allow you to turn the cam to the right position, I always turn the engine over twice using a socket on the crank and refit pins to ensure timing is ok, it is worth letting the tensioner go again too as slack will have been redistributed.
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Did that, worked perfectly.
The cam sproket isnt aligned properly when its turned and pinned, it needs truning backwards slightly, then pulling forward until the pin goes in. It seems like hardly any distance, but it makes the belt fin on properly (with a bit of pushing in the teeth) with more tension.
Spun it twice and the bolts went in.
The engines coming back together nicely, Im waiting on a new themostat, then shes done.
When putting gaskets back on, is it worth putting a film of high temp silcone on all the sides?
thanks for the help!
running on RME/SVO
running on RME/SVO
I’ve just had a go at doing the cambelt and have come across a problem
when i tried to slacken the timing belt tensioner is was stuck fast and would move
After an hour of poking about I ran out of patience cut the belt though and guess what happened
Nothing !! It only moves about a half an inch but it can’t be moved back
What now ?
What now ?
Citroen BX
Origami in plastic and steel
^^bx>
^^bx>
- docchevron
- Vanny
BX 16v Ph2 - XPO - x 82
otherwise you'll have to whip off the engine mount and pull the plunger out as it might have corroded in place. But i've never seen it happen, and i've pulled apart an engine in the scrap yard which was rusty all over (looked like it had been parked in the sea), cut the belt off and the tensioner pinged straight out! I'm not sure they do corrode, best check them bolts!
- Vanny
now that is a PITA, always assumed it would happen but never actually seen it! Reconstruction with Copper slip is probably the way to go, that way it shouldnt corrode again. Personally i no longer have any problems getting the plunger in/belt on, but it is rather fiddly and takes practise to find a method thats easy to manage!
Best of luck!
Best of luck!
Hi Vanny
i posted a new tread on this but maybe i should ad it here so that any one with same problem can see it too
after cutting through the timing belt in order to remove it
I managed to remove the tensioner and mount and found that the plunger was very stuck
so i took RichardW advice:
good advice richard
the plunger was very grotty
this is what it looked like after a little wire brushing
i've now cleaned it up and put it back together with a bit of copper grease and refited it with the new timing belt and water pump
it's the first time that I have done a cambelt on a Bx
now I know what it's like to do keyhole surgery
all running nicely now
with a little heat (boiling water from a kettle) it shot out with a bangRichardW wrote: The (some heat should do it - just make sure you are not stood in the way in case the spring fires the piston out )
good advice richard
Citroen BX
^^bx>
^^bx>
Thanks to Adam's dad for this excellent tip. A junior hacksaw with the blade removed makes a perfect tool for locking the flywheel. You would be hard pressed to design a more suitable tool for the job.
Install the 3 locking pins in the sprocket holes first in order to bring the flywheel hole into approximate alignment, then tweak the crankshaft pulley with a spanner or socket until the leg of the saw goes all the way into the hole.
view from above
view from below
view from above
view from below
David
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
BX19TXD 150k K Reg
Hello everyone,
I will finally have a crack at changing the cambelt on my TD in a few days, and this thread gave me some difficulties while reading it. I'm not a native speaker and though I understand quite a bit of english, all those technical terms don't make much sense to me in english and the dictionary gives me like 30 possible meanings for every word. Actually Google Images makes for better translations
And another question:
Regarding the timing, is it possible to just paint marks everywhere on the pulleys and the engine block to just refit everything the way it was before taking of the belt or isn't that working. Also, to set the timings manually, is there something like this on the BX?
I took this picture from a Toyota Tacoma How-To, where the pulleys are aligned to those numbers to set the timing right. Is that the way it's done on a BX?
And what the heck is that "plunger" thing?
And I always thought I'd need a torque wrench somewhere in this process, isn't that true?
Anyways, this is all a bit confusing, I guess I'll try my luck and get going. If I disassemble all those things, I guess I will understand how everything works.
Is there anything where I need to be careful when removing it, as it would be difficult to refit?
Any help would be appreciated!
What do you mean by "fuel pump locking pin"? And what about the diesel pump?it often helps to remove fuel pump locking pin and slightly rotate pump clockwise before putting the belt on its pulley to get all slack out of the front run
Why do I "need" 3xM8 bolts? I guess they already are in place, I just remove them and reattach them later, right? What is meant by "a suitable drill"? Do I get this right: That there's a deep hole in the middle of the flywheel and I have to remove it with a long socket to get the flywheel off and remove the belt?Yep, all you need are 3 x M8 bolts, one for the cam pulley, and 2 for the pump, then a suitable drill or similar to go through the block and the hole in the flywheel. For the sake of 5 mins, unbolt the starter motor, and you will see the hole in the block, it will be much easier
What pins? Why remove them, where did they come from all of a sudden? Do I need to place some pins there to lock the flywheel?Finally, when the belt is fitted and retensioned, remove all the pins (I usually cable tie the pins with bright coloured cable ties to ensure this!!!!)
Carl
1989 16 Valve
Parts needed:
- One black leather headrest.
1989 16 Valve
Parts needed:
