Hi there, I've just bought a Bx 19 TGD Estate (1990) its all great and very happy with it except driving at night, when the lights are on i don't have any lights behind my speedo, rev counter or fuel gague. I do however have all normall warning lights and indicators etc...
Is this likely to be a simple bulb issue or maybe fuse??? I have seen you have advise on how to change the bulbs so have thought i would give this a go this weekend.
Any other thoughts anyone may have you be greatly appreciated.
Hope to hear soon
Dashboard Lights
Dave
The instrument lights will all fail at about the same time as I found out when we bought our ZX - with one bulb out - and within the next 3 weeks or so the rest went!
The reason of course is close production tolerances - they are made at the same time to the same spec and operate the same number of times - and so all fail at about the same time.
I am however a little curious about the heater ones - being dim. They're never very bright but should be noticeable - and they are never quite as even as you think they should be which is due to the use of not enough bulbs in the right place.
Dave
Get plenty of bulbs - they come out of the plastic holders with difficulty - so if like me you resort to pliers make sure you don't cut yourself. A short length of tube may help in replacing them.
Haynes is quite accurate. I can't remember if it was the BX or the ZX but some bulbs lurked under a cover on the back of a minor instrument.
When replacing the steering wheel make sure you don't bash it down and break the tongue off the indicator cancelling mechanism.
mike st gilles
One other tip here once you've replaced them, is to turn the lights down with the rotating dimmer switch thingumybob; as the dash lights on a BX are on all the time even when the lights are off (if that makes sense). Just need to turn them up when you do turn the lights on (although I've found that even on dim they are normally bright enough without having to turn them up) ............makes 'em last ages.
Mike
BX 16v Ph2 - XPO - x 103
thats a funny idealistic view, as anyone who has ever had to return anything electronics knows tollerances are huge, but usually limited so they all meet a minimum standard.jeremy wrote:
Seriously, on a car this age, if all the bulbs go at the wrong time theres an electrical fault!
Before changing all the bulbs, you need to check that you have a voltage on one side or other of the dimmer rheostat. I'd guess that if all the lights are out then you haven't got a voltage feed to them!
Also, the bulbs, they are of the type used in gamboling machines (also known for every light to blow at the same time, not) and can usually be bought on ebay in packs of 50+ for only a couple of quid including delivery!
