On the way back just before the big hills the water level warning light came on, now bit history on this I have had this problem fro some time replced the sensor yet still there. Strange thing is the Water level seems to be affected on shorter rather than longer journeys.
And sometimes you can check it and suddnly its ok 10 minutes later
You see the dilemma? Blockage or worse.
Well after stopping for a bite to eat topped up the rad with about 3rd litre of water right to the neck. Expansion would just push it out which I think is whats happening.
Got to the top on the big hill stopped for the view and a few photos starts down the hill blow me light on again. 30km to home so ignored it as have done on that short trip before.
Just to drive me nuts Barke Pad wear light flickers on and off well I know that to be untrue. New pads recently!
Some other symptoms though are making me worried although dont seem to affect performance but then the BX will run on 3 cylinders happy anyways.
Noticed when idle as stutter like a spak plug not firing, already replaced a spark lead that was faulty (end came off) anround the exhaust pipe a bit of black sooty residual on the pipe.
I really do miss a decent mechanic friend even the local mechanic is a bit cagey on these things prefering to take the piss out the car choice becaue its not a Holden, Ford or a japper.
Ideas on what to look for a actions to take to check most appreciated
