Urgent! M.O.T. Failure
pinfold
Post by pinfold »
Its that time of year we all dread! The M.O.T.
The 16V has failed on a few things this time including:-
The obligortory "corroded break pipes" allthough what he thinks is a break pipe is actually return leg pipes, young lad, dosnt understand the car! slight bit of rust, what do you expect from something made of steel
Steering rack gaiter?
have sorced everything apart from the gaiter, Gsf cant get me one at all, so im a bit lost as what to do
Any suggestions, before i take out a mortgage fropm citroen, and then have to wait 6 years for it to be delivered?
BX GTI 16V 1991
XANTIA SDX 1996 ESTATE
tim leech
Post by tim leech »
http://cgi.ebay.co.uk/CITROEN-BX-STEERI ... dZViewItem
Any good? Mulleys the highest bidder though, have you tried a local motor factors? you will be surprised what you can get.
pinfold
Post by pinfold »
Thanks Tim
Dont know why i thought of that, not sure what Mulley would say though if i started bidding against him!
I am desperate though! got two weeks for the re test
BX GTI 16V 1991
DavidRutherford
BX Digit man!
Re: Urgent! M.O.T. Failure
Post by DavidRutherford »
pinfold wrote:The obligortory "corroded break pipes" allthough what he thinks is a break pipe is actually return leg pipes, young lad, dosnt understand the car! slight bit of rust, what do you expect from something made of steel
In which case, educate him! I've had to educate MOT testers about my specific vehicle (whatever that has happened to be) on more than one occasion in the past. What he's believed to be a fail often hasn't been.
Prime example of which is CX steering. "That's a fail, you've got too much play"... "err, no. that's how it's designed. Now start the engine and try again"
MikeT
Post by MikeT »
ROFL! I wonder how many Cit's have begun to sink while the MOT man is desperately trying to align his headlight aim testing unit?
DavidRutherford
BX Digit man!
Not as many that have been failed due to no handbrake efficiency.
No, the FRONT axle you complete twonk. You've just been under the car and checked the handbrake cables. Where did they go?
Kevin B
Post by Kevin B »
Its interesting to note that steering rack gaitors are no longer available from GSF, as they were when I bought a set just over 18 months ago.
So theres another item that will be getting hard to source :(
Another thought for you, have you tried Euro Car parts, as they do sell loads of bits in addition to what you will find in their current catalogue.
Good luck and let us know how you get on, as if this is a tricky item I thinking I might get a couple of boot kits while I still can.
Steering rack gaitors are rubbish on BX's anyway, I always use rubber Pug ones. Easily and cheaply available everywhere!
tim leech
Post by tim leech »
DavidRutherford wrote:Not as many that have been failed due to no handbrake efficiency.
Yep we had that when I MOT'ed Ian Fearns TZD for him this year, the MOT tester went the same colour red as the BX when he realised!
ellevie
Forum Treasurer
Post by ellevie »
David
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
I have pm'd pinfold....
stuart_hedges
Post by stuart_hedges »
DR wrote:Not as many that have been failed due to no handbrake efficiency.
Every Citroen I've ever taken to MoT has failed on handbrake efficiency.
I've started to wonder why they even bother.
The only time it's ever been a surprise was on the ZX - that's a conventional car and the handbrake did actually work. I used to park it on some of the hillier bits of Brighton - roads where I have had other cars escape from under me in the past.
Oddly, the only car I've ever owned with a seriously broken handbrake (Saab 99 with a broken lug on the handle, so you could release the handle by knocking it sideways) passed on it. It shouldn't have.
Geoffrey Gould
Steering rack gaitors.
Post by Geoffrey Gould »
Hi mine are not that old (replacement rack) but the near side bit thats about 2" long has all but disintegrated any ideas? Or is it the case of buying a set for just the one piece.
Thank you.
Cheers.
Geoff.
1991 BX 1-7 td Auto.
NEVER WRONG.
AndersDK
Post by AndersDK »
Ask around for general purpose rack gaiters with tapered end bellows. They can easily be cut to fit almost any make of steering rack.
They are available cheeply around here in DK at motor factors. (some £5/ea)
Re: Steering rack gaitors.
Geoffrey Gould wrote:Hi mine are not that old (replacement rack) but the near side bit thats about 2" long has all but disintegrated any ideas? Or is it the case of buying a set for just the one piece.
Thank you.
Cheers.
Geoff.
No worries mate, the rack boots on the valver are perfect! Er, the other valver...
The one with no back end...
Yeah, that one.
