On my 1989 BX 19 auto I have 185/65/14's on handling seems to be ok. By how I understand it the aspect changes on tyre size ie 185/65/14 would be 195/60/15 or 205/55/16 etc I know some tyres on an odd occasion changes aspect on size.
Main difference may be a slight alter of the speedo you may be going faster than you think or slower. Pop down to fast fit they'll put you right
Charlotte001
BX Auto replacement tyres
DavidRutherford
- BX Digit man!
Re: Tyres for BX auto
They're not quite right for a BX. The correct size is 185/60/14, which means your speedo will be reading a little slow.charlotte001 wrote:On my 1989 BX 19 auto I have 185/65/14's on
Slight edit for real-worldness.charlotte001 wrote:Pop down to fast fit they'll employ teenagers, not have a clue about what they're doing, try to sell you whatever they have in stock and quite probably charge you a fortune
155/80 14's I believe were the standard fitment for non-PAS cars, as the smaller width tyres keeps the steering light. Usually these are on 1.4 models. You can change to 165/70/14's without concern. Your steering might get very slightly heavier at very slow speeds, but on the move there will be no difference.
charlotte001
DavidRutherford wrote:They're not quite right for a BX. The correct size is 185/60/14, which means your speedo will be reading a little slow.charlotte001 wrote:On my 1989 BX 19 auto I have 185/65/14's on
Haha you've got it in one My local fast fit are fairly intelligent ok I do tell what brands I dont want though.
charlotte
- x 25
Re: BX Auto replacement tyres
The 16 autos were specified with a narrower tyre for tax reasons in France apparently. You should fit 165/70 14's IMHO. 175s will fit OK but handling will be affected a little bit as the tyre will flex more on cornering.Roger Porter wrote: The original fitment seems to be 155/80s for a BX16 Auto but bigger(wider) for a manual transmission. So the questions are:-
Why is this?
Could i simply change tyre sizes to 165/70 (or even 175/70s) which seem to have the same circumference?
- x 25
Sorry double post. There is something else too - economy will be very slightly better (as will handling in snow) if you chose the (cheaper and more readily available) 165's!
DavidRutherford
- BX Digit man!
Legally, any tyre which is a re-tread must be marked as such. Not that re-treads are as much of a problem or danger as they used to be. After all, most rally cars hammer around on re-tread tyres.MULLEY wrote:Unknown brands can be really dodgy & most are probably re-treads
In fact, I can't remember the last time I even saw re-treaded tyres on sale. New radials are so inexpensive these days that I can't imagine there's a market for re-treads any more.
- Keeper of the site Goat
Tyre anorak to the rescue!
I *think* there's a couple of remoulding companies left, Kingpin were going about 6 years back and Colway seemed quite popular. Half the battle was convincing people remoulds were any good after some of the scare stories about them, and indeed I went to fit a new 'Motorway' remould for someone once that had a nail in it I kid you not.
Anyhow, half the problem now would likely be that cheap crap imported tyres aren't really suitable or wanted for remoulding, it's premium brands like Michelin that are best suited. that leads to the little problem of disposing of old cheapo make tyres and I suspect incineration, shredding and export are the three big avenues seeing as you can't landfill them anymore.
Vauxhall apologist.
