Ever since I got my Kiwi BX I have had this annoying issue of the low warning light come on even after replacing the switch. And yes it was using water somewhere! Seems to have been after 3 cold starts ( yes it was regular) the light would come on shortly after. And in would go about 750ml of water.
Head gasket theories abounded! BUT WAIT!!!!!
Suddenly its fixed itself
Yes I have driven over 3 weeks without putting water in the car covered some 700km and even improved the fuel consumption (cant see the connection) add to that its be the hottest 3 weeks of the year (hottest Summer).
Damn weird but I am not complaining
maybe there actually was a blockage in the radiator or cooling system that was causing the water to be pushed out of the Radiator overflow?
Or maybe this is the final curtain call
and before you say it yes the light on the dash still works as does the level switch.
