Does this really go on a BX ?
http://cgi.ebay.fr/INJECTEUR-205-306-40 ... dZViewItem
One for the diesel specialists
cauchoiskev
Well, they will fit an XUD, and will only work with a Bosch pump.
However I'm assuming the seller is stating that the crack off pressure is 130BAR (my french is rubbish) and I've never seen a Bosch pump XUD with crack off pressures that low TBH...
- x 27
Nowt wrong with off topic, it's called having a conversation.
A dying art I think these days.
Crack off pressure is the point at which the injector opens and allows very expensive and taxed to hilt diesel into the precombustion chamber.
- x 27
- x 27
cauchoiskev
130bar is what they give in Haynes for the N/A Bosch injectors, and the injector holder is the right type, but I was wondering about the injector reference itself (DNOSD 256), Haynes says nowt on that...docchevron1472 wrote:Well, they will fit an XUD, and will only work with a Bosch pump.
Ooh, good point, I was thinking TD, it's been a long time since I've had owt to do with N/A's... How the memory is fading!
I imagine DNOSD 256 is a Bosch reference number.
Given that the pressure's are correct for N/A then there's no reason at all why they wont fit and work perfectley, unless somewhere in the text it says they are Mullered!
DLM
- Our Trim Guru
My turn to crack off. My limited French suggests these are non-BX injectors, but rebuilt with Bosch erm... orifices as per the code.
BX diesel Revue Technique says...
DNOSD 256 injectors are for Bosch-injected normally-aspirated XUDs 1769cc/1905cc up to July 1987.
Pump refs are VE R 171/171.1 for 1769cc, VE R 162 type 516 for 1905cc
D9B 1905cc motor(Post-july1987)
Bosch injector ref DNOSD 287, then DNOSD 287+(after april 88 ).
Corresponding pump refs are VE R 272/272.1/272.2
TD injectors not specified, pump ref VE R 316 type 530
Better still. I've just found tables in Russek that has everything in one place. If you want a scan, PM me.
