http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... Track=true
If so - I might well bid!
Would these fit my BX GTI???
- x 25
- Keeper of the site Goat
Cornishbx16v
what you will need to get them to fit is a 10mm spacer, the offsett is too high for the bx as the bx is 15-22mm so a 10mm spacer will put these at 19 which is perfect! i am not too sure what they would look like on the car though??? but if they are cheap and tyred up does is matter??
just checked the advert, he has them down as 100pcd which isnt the fitment for the 405 they should be 108, worth checking, but i am almost positive that they are 108 not 100!
Stewart (oily!)
I once got hold of some genuine 405 alloy wheels, they fitted the front wheels ok but needed slight modification to go on the back, the holes through the centre were too small and needed clearancing a little and they needed holes drilling to accomodate the locating lugs, neither things were difficult to do.
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
