Question Foglights and Interior Clock
surrey_man
Yahoo Messenger: surrey_man1982@yahoo.co.uk
Post by surrey_man »
Hi all ok where to start ok fog lights
right well ive got some halfords driving lights these where going to go into my AX but thats taken a hit in the wing and is off road so now am thinking there go lovly in the BX but i know they never whent stright into the AX bumper (GTI style)
But will they fit the BX or need some form off brackets made??
also the ZX Interior Clock is that the same as the BX one?? as my clocks not working and how the hell do you pull these out?
cheers
Jon
Jon MISSING hes BX 17 TZD
and the Smasshed up Escort est
You should be able to fit foglights by cutting a few of the slats out from the lower grille. Behind the grille (on mine at least) there should be 2 holes (1 on each side) that you can mount a standard light bracket to, so no drilling required!
The clock is removed by taking out the odds and ends tray, 2 screws at the front hold it in. You will probably find that it's just the bulb - try a new bulb first. I think it's the same as a ZX clock although someone (Jeremy, Phillip?) who has experience of both will, I'm sure, correct me if I'm wrong...
surrey_man
arh the odds and end trays are no where near the clock its up in the middle of the dash its on a L '93 i think theres 2 diffent styles off dash
Ive got the fog lights installed and all working just wondered how easy it
was to just replace them with the driving lights ive got
Does your dash look anything like this?
If you look on the left that recess is what I was calling the odds and ends tray...
surrey_man
yes looks like mine althou i dont have that thing under the cig litter
the "odds and ends tray" is that the flat thing that goes around the clock? this is what am at a lost on removing :lol:
Extra controls under the Cig Lighter are controls for Air-con ehen fitted.
Info was correct for removing odd& ends tray to access clock. :D
surrey_man
cheers for help ill have a look at it tomorrow
them screws are by the clock ?
No, they are at the front of the tray, one above the cig. lighter and one above the RH vent. It'll be easy in the light!
stuart_hedges
Post by stuart_hedges »
Have we met on a forum before, surrey_man? There's something familiar, I just can't put my finger on it?
Terry Brooks
Location: No 1 at the end of the bar .....@Milton Arms,Rotherham
Post by Terry Brooks »
Hi jon ...........and welcome to the forum .......you seem to be having a few probs with your tizzydee .......where did you buy it from,we may know it,and if we can work out it's history,we may be able to help with the probs you're having.
best regards
Terry
surrey_man
stuart_hedges wrote:Have we met on a forum before, surrey_man? There's something familiar, I just can't put my finger on it?
Yea same here i swear ive seen your name before some where
Are you on redhillandreigate forums? (or webmaster ?)
AX club or overclockers.co.uk??
Live in Crawley west sussex and go to ICC ? is buggging me too lol
surrey_man
Terry Brooks wrote:Hi jon ...........and welcome to the forum .......you seem to be having a few probs with your tizzydee .......where did you buy it from,we may know it,and if we can work out it's history,we may be able to help with the probs you're having.
best regards
Terry
Got it out the Friday Ad from Caterham Surrey its reg is L773 KKY BX17 TZD white its got a lot of paper work withh the car and has had a lot of things done to it in the past
surrey_man
mat_fenwick wrote:No, they are at the front of the tray, one above the cig. lighter and one above the RH vent. It'll be easy in the light!
am so blind i cant find them :oops:
nstarmore
Post by nstarmore »
Don't worry I had trouble finding them as well and had to have them pointed out.
They are in the front lip of the tray (nearest you when you are sat in the car) and are both in the position mentioned above but the heads face the windscreen so you can't see them unless you look at the inside on the lip from above.
Hope thats a bit clearer
Nic
- 1995 Xantia SX TD (daily hack)
- 1987 BX 16V (project)
surrey_man
Arh now that would be why ive not seen them
Ive been looking on the outside of the tray ill have another look tomorrow
