TD bottom water hose
RKM
Post by RKM »
As I have a nearly new radiator to put in my BX, I have noticed that the bottom hose is a bit soft, especially at the ends where engine oil has got at it.
The dealer can supply one (@ £40) but does anyone have a new one at a cheaper price, or can recommend where I can get hold of one?
The car is a 1992 TD estate.
Cheers everyone!
Post by ken newbold »
I have a brand new one here. Make me an offer and it's yours :D
RKM
what's happened?
Post by RKM »
Well, a cheque was sent at the beginning of the month but nothing has been received yet.
IS everything ok with Ken?
Rob
As far as i'm aware, have you tried pm'ing him? if not try the xm forum incase anyone on there knows anything???
RKM
re
Post by RKM »
yup, PM'd him a good few days ago but no response yet. Is he on holiday/ill as he hasn't posted for a bit on here.
dunno, might be on his hols?? i presume the cheque has been banked? i wouldnt worry too much as Ken is a genuine chap. If you havent heard anything in the next few days, update this thread & i'll see if i can contact him on your behalf....
Hope that eases your worries a bit....
RKM
Post by RKM »
Thanks Mulley. I have e-mailed him via the XM forum so I suspect he has a stalker!!
DLM
Our Trim Guru
x 13
Post by DLM »
If whatever hose you end up with doesn't fit - then make a note of your reg number and your RP number and go hotfoot to a co-operative Citroen dealer*. Then be sure not to take the easiest answer - or a brush-off.
I discovered the hard way that 1992 TDs had at least a couple of different variations on cooling-system pipes when my last TD started to leak behind the engine. In the end it came down to a cut'n'shut solution behind the engine, and a pair of different bottom hoses being ordered as I discovered the advanced state of rubber decay around the collector-box.
* Note - A "co-operative Citroen dealer*" is often, though not always, the kind that has a parts man of "advanced" years. I've heard the sound of sucking teeth and barely suppressed groans/disgust from Citroen parts neophytes rather too often in the last couple of years. To be fair I've also met a couple of younger partsmen who were right on the ball - exceptionally helpful - but fewer of them.
