Hi there!
I have a December 88 16RE. The switch for the handbrake indicator light has become tired and is not always springing back, so I was wondering if someone out there had one that they could sell me? As she's done nearly 160k, I guess it has been depressed a few times!
Thank you
Bets wishes from Neil
Handbrake indicator switch
Neil
Best wishes from Neil
DLM
- Our Trim Guru
With all due respect Neil, REMOVE your address from the forum and send David a privtae message via the PM button.
This is a public forum, and any wierdo can see it, best to play safe.
You should be able to edit your address out? or has the site changed?
stuart_hedges
Had to post 1st to double check, on the far right hand side should be the edit icon....
