funny thing is i have two of them! and there both KKK!
Tahnks for the offer Jon, as said i have two spare turbo's and i actually have a spare head that i've been holding for a few months, however the one on the car is nearly brand new!
As a brief update, i dropped a gear to overtake another car on the A55 earlier and no longer have a whining turbo, infact i dont really have a turbo any more! Once it gets above 0.5 bar, oil levels rapidly diminish (about 100 miles per litre when driven hard) and it seriously sounds like there is a jet engine under the car. Think the various seals have totally failed now!
Oh the hesitation has reappeared and the nice man who lent me the stop solenoid thinks its bits in the pump coliding and bits coming off inside the pump!
So, i have an engine that has slipped its belt requiring a new head and having left marks on the pistons! A fuel pump literally falling to bits, and a blown up turbo! Total cost in parts to FIX the engine are pretty much at £100, so all in all after i've fixed the pump and turbo i probably could have bought a HDi and stuck that in! Typical!
Getting closer to MOT!
- Citroen Sorceror
- Vanny
BX 16v Ph2 - XPO - x 82
Think the rate im going im gonna have to have a trip down to visit you jon!
The saga continues!
as mentioned before when the engine change was done the bolts holding the intermediary joint on the long side drive shaft (BX16v) weren't tightened up! Found it when said relacement engine needed a head change, but had done a good 1000 miles on it! Oil seal was destroyed on the diff box.
Now when driving and on a full right hand lock there is a very loud routine thunk thunk thunk at the same speed as the road wheel rotation. Can i assume this is gonna be down to a goosed driveshaft?
I think im havign a rather bad car year! THough now i know better than to trust a dodgy looking engine, it has become the baine of my life thats for sure! would have been faster and cheaper to rebuild the 1.9td in situe, and if i had know how buggered the replacement engine really was i would have never bothered
The saga continues!
