Tyre brands
So if skinny tyres are safer, why arent they fitted to new cars anymore?
Erm, there's so many different reasons for that we could have started the longest thread of all time to get to the bottom of, and it'll use all the bandwidth in the whole world!
Not stated safer, just that there are pluses and minuses.
With regard to new cars, probably has more to do with aesthetics in that modern cars are more 'bloated' than earlier models and probably on the majority ABS has become a standard feature. (ABS is unlikely to help you once you are aquaplaning though!)
jonathan_dyane
1) Apparently big wheels with rubber tyres 'look sexy'.MULLEY wrote:So if skinny tyres are safer, why arent they fitted to new cars anymore?
2) It's an easy way of making something seem to handle well (in the dry) even if its suspension and weight distribution is somewhat lacking.
3) Repeat 1)
To a degree I think it is a matter of taste, and as such is subjective. I prefer the ride and driving characteristics of skinnier and taller tyres, and theory (and my experience) suggests that in adverse conditions they provide more grip. I also think that every new/newish car I've been in has ridiculously stiff suspension, giving an uncomfortable and terribly fatiguing ride, and also undermining grip on undulating corners.
I can only speculate that this must be what the buying public (or more specifically focus groups) want...
cacaolat
I have read test results last week, which confirm the fact that slim tyres are safer in aquaplaning.
Hey.. I am just putting on the standard size tyre, which the car is designed and tested for.
cacaolat
here is the test...but sorry it is in german
http://www.adac.de/Tests/Reifentests/br ... ageID=8762
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Correct but mechanical grip (contact between road and tyre) doesn't exist when aquaplaning. Skinny tyres offer less grip that is true but have a higher resistance to aquaplaning (all other things being equal that is).MULLEY wrote: Perhaps the aquaplaning principle does corrorborate the theory that skinny tyres are less likely to aquaplane, however, by the very nature of the fact that they are narrow, they have less mechanical grip
Most road conditions are predictable so you can drive according to the conditions of the raod/weather/tyres etc. Obviously aquaplaning is unpredictable so best to reduce likelihood of occurance with skinny tyres.
As with everything, it's a trade off and 99.99% of the time a car isn't aquaplaning so fit bit fat rubber and impress Joe Public with the 'handling' and 'sporty appearance' of his latest german aquisition.
On that little note; I had a sit in the new C5 today - I felt somewhat disappointed although it seems - you know - car like
cauchoiskev
- x 27
Uh? I can't see how this can be the case. Can you elaborate?cauchoiskev wrote:People think that a fatter tyre will put more rubber on the road. It won't.
For a given weight on the tyre and a given tyre pressure, the contact patch area is exactly the same whatever the width of the tyre is. The only difference is the shape of the contact patch.
cacaolat
sorry forget to say...the test does however also say that wider tyres tend to be safer when braking and in curves...(exept comfort and aquaplaning)
but I still feel the standard size good quality brand is better than a rubbish quality super wide tyre
I agree, but when you have quality wide tyres, then no probs
Infact, i'm only using the spec of tyres that were fitted to the 8v gti & wasn't the valver fitted for 195/60's, so if those models are suitable for the wider tyre, i see no reason why they cant be used on the other models.
Werent TZD Turbo's which had abs, fitted with 165/70's?
