Electric Diesel fuel heater
ed4ferrets
- Yahoo Messenger: [email protected]
Earlier BX's were fitted with these, anyone have one for sale?
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
ed4ferrets
'94 XM 2.1TD Break
'94 XM 2.1TD Break
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO!
Especially not on a Lucas pump!
You'll kill it!
BTW, what the bleeding hell are you doing up at this time of night mate?
You'll kill it!
DavidRutherford
- BX Digit man!
CitroXim
- Sir Jim of the Databases
Yes, I'll second that. Lucas pumps are great performers but such delicate little flowers. They like only real dino diesel with added lubricity and if given a strict diet of that, last forever and a day. Even if they become incontinent in old age, as they frequently do, it's a doddle to replace their seals.docchevron1472 wrote: You'll kill it!
I rate them as being better performers than the Bosch VE. The only thing the Bosch has going for it is it's toughness.
When I strip my dead one I hope it'll reveal just waht damage veg or bio does to them. It can act like the health warning on the side of a fag packet...
Later XUD's had a small fuel heater under the fuel filter housing and it was thermostatically controlled. In the cold the fuel runs around a labyrinth cast into the thermostat housing before entering the filter proper. These can be recognised by the fact thay sit on top of the thermostat housing and have a domed lid. I reckon it would be feasible to transplant one onto an earlier XUD by exchanging the whole thermostat housing.
However well you heat veg before showing it to a Lucas, it'll still spit it's dummy eventually. If you really want to go veggy, a Bosch pump is an absolute must.
Jim
DavidRutherford
- BX Digit man!
What early XUD-engine'd BX's did have was a fuel pre-heater built into the water pump inlet manifold, on the back of the block. These were notorious for going porus, and were a bit of a load of bollocks really. Bypassed, the engine still works just as well as it ever did.
For a decent veg-oil set up, you need twin fuel tanks, a change-over (divert-type) valve on both the flow and return, pre-heating, line heating, tank heating and a shut-off fuel bleed timer.
And a bosch pump. (although a Lucas one will last a very long time if the setup is done like this, as you never overload it with viscous SVO, it's always at temperature.)
I've had plans to do this for ages (and now finally all the bits) I'd budget on spending the best part of £500 to do it all properly.
Thereafter you do of course need a supply of oil, and the ware-withall to pre-condition it as necessary (filtering, handling etc.)
A lot of effort really. Does your mileage warrant it?
Veg oil is still more expensive that diesel, so i've stopped using it....
Dont know what their prices are like, however, i doubt its 50p a litre cheaper than diesel which is what it used to be & worth taking the risk for pump damage.
If its just a few pence cheaper, i'd rather use bio-diesel which is slightly safer. Infact the best oil to use is sunflower, its got a lower viscocity & can work much better in winter (doesnt freeze as easily) than standard rapeseed, downside is that its more expensive.....
CitroXim
Lucas seals fail even on the finest dino Mat. It's very common to find a Lucas weeping from the throttle and fast idle spindles. The upside is the seals are very easy to replace and it can be done in-situ as wellmat_fenwick wrote:Don't the seals on Lucas pumps tend to react badly to anything other than dino diesel, or have I been misinformed?
Experiments I've done with old Bosch seals show they react to veg after a while and on the Bosch it's a much more involved job to replace them. new seals though are good for veg and bio, being (I believe) made of viton.
Jim
jonathan_dyane
No, assuredly UK BX's were indeed fitted with the electrical diesel heater in question, my grandfather purchased an early MK2 19RD estate when it was about 3 years old (registered late '86 IIRC) which was fitted with a Bosch pump and the electrical diesel heater. I believe C15D vans of the same period were also so equipped...DavidRutherford wrote:I'm less sure that such a thing ever existed, certainly for the UK market anyway.
There are plenty of aftermarket inline fuel heaters out there, but you'd be better off with a fuel/coolant heat exchanger.
Erm, I rate the Bosch MUCH more highly than the Lucas, although my car is presently equipped with a Lucas pump. Although that will change.citrojim wrote:I rate them as being better performers than the Bosch VE. The only thing the Bosch has going for it is it's toughness.
You can just do so much more with the Bosch pump if you're methodical.
When you get it all setup just right the Bosch pisses all over the Lucas.
Yep, it's dead easy, and a good thing to do!CitroJim wrote:Later XUD's had a small fuel heater under the fuel filter housing and it was thermostatically controlled. In the cold the fuel runs around a labyrinth cast into the thermostat housing before entering the filter proper. These can be recognised by the fact thay sit on top of the thermostat housing and have a domed lid. I reckon it would be feasible to transplant one onto an earlier XUD by exchanging the whole thermostat housing.
Agreed. they are pointless PITA things.David wrote:What early XUD-engine'd BX's did have was a fuel pre-heater built into the water pump inlet manifold, on the back of the block. These were notorious for going porus, and were a bit of a load of bollocks really. Bypassed, the engine still works just as well as it ever did.
- Keeper of the site Goat
Even ten pence per litre cheaper is worth it though surely? I ran a BX almost entirely on vege oil for quite a few months and far from harming it I swear it actually ran better, cleaner and faster on the stuff mate.MULLEY wrote:Dont know what their prices are like, however, i doubt its 50p a litre cheaper than diesel which is what it used to be & worth taking the risk for pump damage.
Vauxhall apologist.
