leak off pipes and end caps are so easy to do its best to try them first before getting all technical
Leaky Diesel Injector
It's hardly technical.
If it leaks at the joint (where the two halves of the injector join) then it's not hard to put a spanner on the top part of the injector and give it a tweak (handily both bosch and Lucas injectors have flats in the top of the injector body for just this very purpose!).
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
I thought I had this problem a few months back - a leaky injector that is. In the end it was the leak off pipe or end nipple but as they were new I removed the injector and tightened it up some. Bloody annoying to do all that and for it to be leak off
That does bring me to another point though, I had separated the injector halves to clean them up etc (although they were all very clean inside anyway
) but what is the correct torque to tighten the two halves back up?
Ahh the torque setting required there is "Tight".
No idea TBH, I usually just do them up so the thread doesn't strip, if it does, I know I did it up a tad too tight...
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Well, I did do 'em tight, but then re-tightened the one that I thought was leaking....but that means that one injector is done up tighter than the others which surely means the internals are compressed that little bit more leading to lift pressure differences across the 4 injectors...
Ian_Fearn
Yes, this is true.BX Bandit wrote:Well, I did do 'em tight, but then re-tightened the one that I thought was leaking....but that means that one injector is done up tighter than the others which surely means the internals are compressed that little bit more leading to lift pressure differences across the 4 injectors...
Can't say I've ever noticed any adverse effects mind.
I've only ever done them up by feel, but I guess it would be the done thign to go find out the correct torque setting!
I'll ask the guys on monday..
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Yeah, it'd be nice to know. As you say, the differences will be small, but when you consider what we spoke about (can't remember when!) injectors getting 'tired/worn' partly due to spring fatigue then I would of thought an extra 1/8th of a turn would make more of a difference.
Then, when you consider the differences in cylinder pressures you'd of thought that the differences are more than large enough to offset spring fatigue and 'injector torque ups' put together (although cylinder pressures and fuel atomisation are two completely different things)
(sorry to those who find this dull or incredibly anal!)
