Leaky Diesel Injector
Ian_Fearn
I've got a very slightly leaky injector (the one closest the gearbox). It seems to be slowly getting slightly worse.
Is there a rubber type seal on the injector that could have deteriorated or is it likely to be something internal to the injector?
Cheers, Ian
Cheers, Ian
Over and out from me
Linegeist
There's a flame proof washer that sits between the injector and its hole in the cylinder head that sometimes gives rise to such leaks. I had one like it last year that manifested itself as bubbles from the injector base. All I had to do was nip the injector up slightly using the special injector socket.
If the washer's too far gone, then they're easily obtainable and simply replaced.
Ian_Fearn
Linegeist
Ian_Fearn
Afraid i'm with Bob, just been out and bought oneLinegeist wrote:Nahhh! I'm just a sad old git with too much spare time, and who loves shiny toys hanging on his workshop wall.mat_fenwick wrote: Perhaps I'm just a cowboy...![]()
Any idea where to get replacement seals from? Is there an online source?
Brian
- x 117
Actually there are two sealing washers. One is a bit like a spark plug washer and this is one that can leak out onto the head if the injector is not really tight. The flame check washer is an internal seal and will not cause an external leak unless you have two fitted by mistake preventing the injector from fully seating.
But check the leak hoses as Brian suggests and the diesel union for leakage as well.
im with checking the leak off pipe's/end cap first, buy a MAFCO blister pack it contains a length of the proper pipe and usualy two end caps for just a few quid
Ian_Fearn
i have never been offerd two diferent size's before, but i would go for the 3.2mm as it will stretch a bit and it will be nice and tight
Ian_Fearn
Ian_Fearn
