The 'door open' switch is located physically inside the door lock motor.
Your problem will likely be a break in the wiring between the door and the car.
Computer wiring
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
scrappydoo
scrappydoo
prm
With the bonnet open display, you need to work through the circuit.
First check the bulb, a 9v battery, with short leads helps. Remove the switch, check to see if this operates, open and closed. Then check continuity of the cable - bonnet to display unit, pin 7. You should? have a circuit. On the rear of the display unit where the bulb holder locates, check to verify connection with the two half-moon copper contacts. One section should be + supply, the opposing section should be too pin 7,
and confirm the bulb holder contacts are making a connection when installed into the display unit.
The above operation applies to all the other display operating circuits.
Regards
Regards
rayfenwick
- Yahoo Messenger: otis_wilbury_ii
I used to live near Podolsk...Vanny wrote:A very quick Google brings you to this website;
http://citroen.podolsk.ru/bx/docum/haynes/
ignore that the text on the screen is not in english, the links are. The top link is to the electrical diagrams in the Haynes manual.
Ray
www.citroencarclub.co.uk
