where can I get a rear height corrector
BX Meteor
Post by BX Meteor »
Malcolm ..... I knew what you meant about the extra holes, but I don't get how the XM correcotr would mount in a BX as a direct fit ... or would it be a direct fit ?
[well as it turned out, the rear one on my car may not be leaking, as the short rubber pipe connecting corrector to plastic pipe was slightly split, so it looks like I will never find out in practice now]
i think it will be a direcyt fit, as on all later full blooded hydraulic citroens, the diference is the style/type of linkage's, and the same old H/C is just bolted by the same bolt holes/points to a diferent carrier/carridge/linkage (far more complicated)
but the actual H/C remains more or less the same,
BX Meteor
Post by BX Meteor »
hope I never have to replace a H/C, but I would be less intiimidated now, many thanks
