Breaking 1.9 TGD
rayfenwick wrote:
There's a ball bearing in one of the pipes at the LHM tank IIRC - could a missing/stuck/mislocated ball bearing cause it somehow? We're really shooting in the dark....
Originally they had ball bearings in one leg of each strut return with the theory that a pumping action of the waste fluid would be created when the struts operated normally for suspension action.
New replacements for strut returns no longer have this ball bearing valve fitted because presumably the theory did not work so well in practice and it worked no worse without them.
I'm not sure about the ball valve near the LHM tank whether thats another valve that it would work without ok or whether it serves a vital purpose. :? I expect someone else will be along shortly to answer this one. :)
djm666
bx bits
Post by djm666 »
hi there, have you got the sunroof motor and the tray in the middle of the dash? i would be very interested if you wanted to part with them.
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
Nat
Post by Nat »
I'd be interested in the passenger sun visor and the windscreen wiper stalk. Also, what rear lights does it have? They don't happen to be gray smoked do they? One of mine got replaced with a green one in the past and I'm looking to make them match...
1991 BX 4X4 GTI back on the road :)
rayfenwick
Post by rayfenwick »
Way2go wrote: I'm not sure about the ball valve near the LHM tank whether thats another valve that it would work without ok or whether it serves a vital purpose. :? I expect someone else will be along shortly to answer this one. :)
Anyone? :roll:
Ray
www.citroencarclub.co.uk
richardd1652
Post by richardd1652 »
I think the rear lights are green tint but i have several darl smoked tail lamps here in the garage.
Richard.
richardd1652
Yes i have a sunroof motor whether its off the car or in the garage. It has centre tray on dash.
Richard.
richardd1652
Got a sunroof motor already off.
Richard.
djm666
sunroof motor and tray
Post by djm666 »
I am going to aus for 2 weeks on tuesday, i will get in touch and sort out a courier to pickup when i get back, if that is ok?
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
djm666
Post by djm666 »
also what sort of money are you looking for them?
David Musk
TXD Turbo 92
4X4 Estate 90
CX25GTi Turbo 85
