rear sphere removal - help
BX Meteor
i have never resorted to the hammer/chisle method,
and the seem people are talking about is a weld joint were the two halves of the sphere are welded together,
this is the type below of chain wrench i use with a 2 foot tube over the end, had it for quite a few year with no prob's,
http://www.tooled-up.com/Product.asp?PID=175239
if the handle of your wrench has bent it aint the right type,
mountainmanUK
I bought one of these around 4 years ago. Used it several times.....always successfully!
http://cgi.ebay.co.uk/citroen-xanta-sph ... 43a6cf5413
BX Meteor
I've had my chain wrench for over 20 years and only used it to remove oil filters. I think it was one of the cheapo varieties though, handle NOT entirely like yourscitronut wrote:http://www.tooled-up.com/Product.asp?PID=175239
i do have a second sphere removal tool of the type we used to have in citroen service workshops,
which is similar to that ebay thingy but far more substantial,
and the band is split spring steel with a 17mm pinch bolt to pull it together tight against the sphere, once attatched you just give it one or possibly two swipes with a club hammer,
BX Meteor
The one from ebay came yesterday. It's obviously not Citroen, probably "homebrew", looks like a blacksmith made it one day when he had no horseshoes to make !!citronut wrote:i do have a second sphere removal tool of the type we used to have in Citroën service workshops,
Linegeist
Because hydraulic pressure was still inside the sphere and creating tightness at the threads. This why we said you should just crack the spheres and then release the pressure.BX Meteor wrote:The offiside went loose in less than a quarter tuirn, the nearside was tight for more than quarter turn, so then I put suspension to low and it went loose as well. Not sure why that is
You may have just had a close shave ..............
BX Meteor
It's a long thread so I don't see the danger, unless you're proposing it's a squirt of fluid that would cut me at 2000 psi, which is possible, but I was at arms length anyway (I don't fancy working under a car with pipes at 2000 psi in the first place)
Linegeist
its more the damage the shpere might do when being propeled by the force of the citro blood under presure
besides that it could also damage the thread in the suspension unit,
i have seen fluid shot a good few yards from a completly dead sphere removed that is full of presurised citro blood,
and that is with the system de/presureised,
rayfenwick
- Yahoo Messenger: otis_wilbury_ii
It wasn't Peter North's BX, was it?citronut wrote:....i have seen fluid shot a good few yards....
Ray
www.citroencarclub.co.uk
BX Meteor
not sure what the pressure is on the spheres on high suspension, but assuming it's approx 100 bar .... then that would be equivalent to a depth of 1km below the sea.
The Soviets made some titanium double-hulled nuclear submarines that could reach that depth.
On January 23 1960 a manned submersible the Trieste reached the bottom of the Mariana Trench in the Pacific, approx 10km down.
I saw a documentary about that years ago and they said that water through a pin-hole in the hull would cut a person in half
Linegeist
Look on the bright side. You're never alone with schizophrenia.BX Meteor wrote:I saw a documentary about that years ago and they said that water through a pin-hole in the hull would cut a person in half
As an aside - I think you'll find that the Alfa class subs couldn't actually reach the astonishing depths claimed by the Soviet Union - and for the same reasons their (ripped-off) copy of Concorde, The Tupolev T111 couldn't fly supersonic (or in inclement weather .... or when there was an 'R' in the month). Quality control, materials and technology. The one Russian submarine that did get really deep is still on the bottom of the Barents sea - the Komsomolets.
I used to teach Intel stuff in the army and I think you'll find that the Alfa myth contained a lot of propaganda. However, the Alfas DID have hydraulic suspension - when submerged. This was a rather neat trick that would be a bit of a deal-closer for a BX.
They may have been good, but not THAT good!
BX Meteor
another documentary ... on the real reason for the Concordski crash at the Paris air show
the French had a Mirage fighter up in the clouds filming the Concordski because it had similar canard winglets that the French had on their Mirage. Unfortunately they did not tell the russian pilot of Concordski and while he was climbing he saw it in the clouds and he pushed Concordski into a dive to avert a collision. As Concodrski went over the top, its engines stalled (this would happen to most engines of that era) and he kept Concordski in a dive while trying to restart the engines.
When the engines restarted he had run out of room and it broke up when he tried to pull it out of the dive (this would also happen to many planes when pulled fiercely out of a steep dive).
There was a secret meeting between the russians and the french, and they agreed to keep this secret and the french paid off the russians, and the russians decided not to continue with concordski as by then everyone knew supersonic passenger planes were not economical. This secreat went past the 30 year rule and the documentary was made just over 10 years ago.
