rear sphere removal - help
BX Meteor
In "BX Technical FAQ" there is a nice post Changing Spheres
In the section "Changing the Rear Spheres" at one point it says
.....Loosen both rear spheres no more than 1/4 turn using the sphere tool, or a chain wrench. The rear spheres may be "tight" due to corrosion. You can try and loosen them using a cold chisel and a hammer .....
There should be a ridge line a bit like a weld on the sphere down one side, i believe it's this that the chisel needs to be against & wacked hard.
I presume that you've got it on High whilst trying to loosen them (don't remove them when in high)?
Linegeist
Yep. Matt's dead right. Put the suspension on 'high' which will put the suspension under load preventing the sphere carrier turning and place axle stands under the car.
Place a sharp cold chisel onto the weld seam and gently create a slot. Once slotted, you can then deliver several sharp blows to the sphere in an anti-clockwise direction which should 'crack' the joint. As soon as the sphere moves, STOP!
If you continue, there is a danger of LHM emerging under VERY high pressure from the sphere to suspension joint!
At this point, once the sphere's turning, you can release the suspension pressure, and undo the sphere using your chain wrench, at which point a small LHM will emerge. This is normal.
BX Meteor
Aye I did have it on high and I understand that it's only on high for the first 1/4 turn to make sure it is "lose".
The car is not on axle stands any more, I will have to check tomorrow, I don't remember seeing a ridge line but I could be wrong.
I've just looked on the front spheres and there is no ridge line there, nor on the new rear spheres (GSF, I assume they haven't sent me front spheres). There is a ridge on all those, going round the circumference, but not "down one side"
EDIT: I must have crossed with Bob's post, I think I undertsand that one, I'll let you know when I try again (if I'm still alive LOL)
You could always just give the whole thing a few taps with the hammer, it does help to loosen the grip.
Also, keep one eye on the cylinder itself, not easy I know, but if it should start to move (turn) do not proceed, or you will rupture the feed pipe, then you have one hell of a nasty and expensive job on your hands.
BX Meteor
I might try "tapping" it first, thanks.
Question: why does having suspension on high position stop the cylinder from turning .....I assume that if I had an unstopable force from a non-slippable chain-wrench with an un-bendable lever, the cylinder is not an immovable object even with suspension in high poition
In full height, there is much more pressure holding the cylinder fast.
In extreme cases where the cylinder has wanted to turn, another idea is to load the boot with paving flags or bags of sand or similar, more weight the more the pressure.
It goes without saying that you'll need the wheels on the ground or on ramps for this operation, so I won't say it
Bob's described the process of how to get the chisel into the sphere. From memory, i thought all spheres had this ridge?
BX Meteor
Probably my poor description tbh
So it looks like the top half has been welded to the bottom half, rather than down the side from top to bottom as i'd said?
BX Meteor wrote:Yes the ones I have, have a ridge like a circle round the sphere, but not down one side.
Place the chisel on the ridge at an angle pointing into the sphere but also angled towards the undoing direction of rotation, then smack the chisel hard with at least a 2lb club hammer!
BX Meteor
I think so, but only on the ones I've definitely looked at tonight with my eyes connected to my memory system, which makes four in total (2 front spheres in the car and 2 new rear spheres from GSF)MULLEY wrote:Probably my poor description tbh![]()
Circumference, that was the word i was looking for
BX Meteor
Linegeist
