Sourcing a replacement accumulator
if it work here is page one cut n paste,
LHM Leak - help
Postby richardmorris » 08 Mar, 2011 - 12:05
Hello all,
Have just had this email from my brother-in-law - anyone have any ideas for a source of the leak?
xantia playing up again!!!! Got the hydraulic fluid warning light again this morning and had to stop on the way to nursery. Got back and topped up the reservoir and then waited to look for leaks. Seems like there is fluid coming slowly from around the sphere at the front of the engine (reservoir sphere?). there is a black connector block under the sphere that connects to some relatively wide bore piping and the leak seems to be coming from around here. Looking at the drive it appears that it may have been leaking for a little while.
Any thoughts apart from a big bonfire?
Lee
Richard Morris
C5 2.0HPi Exclusive,2CV6 Spécial, Fiat X1/9 SE
(Xantia Stateside, C3VTR+, Renault Scenic in the family)
Thames Tortoises 2CV Club Contact
Re: LHM Leak - help
Postby richardmorris » 09 Mar, 2011 - 16:43
Update.
Seems he's managed to sheer one of the pipe nuts when attempting to tighten them. Oh well. Seems the RAC beckons...
Richard Morris
Re: LHM Leak - help
Postby robertsmart » 10 Mar, 2011 - 20:59
Hmmmm, sounds like he has scrapped the pressure regulator then! Thats probably where his leak was from. If he manages to get the bit of the pipe union out, there is a bit in my last Xm column about replacing the seal in the pressure regulator.
Re: LHM Leak - help
Postby richardmorris » 11 Mar, 2011 - 08:31
robertsmart wrote:Hmmmm, sounds like he has scrapped the pressure regulator then! Thats probably where his leak was from. If he manages to get the bit of the pipe union out, there is a bit in my last Xm column about replacing the seal in the pressure regulator.
Having seen the pics I agree.
Mechanic is going up Saturday to see if he can get the remains of the thread out and put it all back again.
Richard Morris
Re: LHM Leak - help
Postby richardmorris » 26 Apr, 2011 - 11:08
Well that last leak was fixed with a replacement regulator. BUT it seems the new one also has a leak, if a little slower.
It's coming from the end- arrowed in the photo.
Can this be repaired at all? it's a slow drip at the moment, so not yet catastrophic.
AND
if anyone is interested in buying the car let me know - one family owned, V reg 150K 1.8 16V stateside - engine, body and interior very good.
Richard Morris
Re: LHM Leak - help
Postby Malcolm » 29 Apr, 2011 - 09:58
what happend to the old regulator now its off the car it might be possible to salvage and re/fit it,
Malcolm
Re: LHM Leak - help
Postby robertsmart » 29 Apr, 2011 - 11:16
Hi Richard,
The seal inside the pressure regulator is the likely culprit, take a look back to one of the recent Xm articles in the magazine, it shows how to replace it.
Re: LHM Leak - help
Postby richardmorris » 02 May, 2011 - 10:55
Malcolm wrote:what happend to the old regulator now its off the car it might be possible to salvage and re/fit it,
We're already thinking of that - but rick can't quite remember where it is in the workshop (or which car it may be in)!
The base of the old one was rusty and pitted making a poor joint, but it wasn't leaking from the end.
Richard Morris
Re: LHM Leak - help
Postby OldBill » 15 May, 2011 - 22:19
I've just found that my 1998 TD auto has a leak from the end plate as in the second picture and I have been trying to find a diagram of the internals to see if I can repair it. I have a regulator/accumulator from a GS perhaps I could fit that?
Not much help for your problem just a coincidence.
oldbill
OldBill
Top
Re: LHM Leak - help
Postby richardmorris » 16 May, 2011 - 07:37
OldBill wrote:I've just found that my 1998 TD auto has a leak from the end plate as in the second picture and I have been trying to find a diagram of the internals to see if I can repair it. I have a regulator/accumulator from a GS perhaps I could fit that?
oldbill
According to my friendly mechanic "oh they all leak there".
Richard Morris
Re: LHM Leak - help
Postby Malcolm » 17 May, 2011 - 07:19
there is an O ring in under the end cap and it can be replaced, but you will need to compres the spring that is in under the cap before removeing the circlip,
also there are exploded diagams of a regulator in earlier citroen BOL 's like the G, BX and CX manuals,
Malcolm
Top
Re: LHM Leak - help
Postby richardmorris » 17 May, 2011 - 07:39
Malcolm wrote:there is an O ring in under the end cap and it can be replaced, but you will need to compres the spring that is in under the cap before removeing the circlip,
Thanks Malcolm. I'll pass the info along.
Richard Morris
Top
Re: LHM Leak - help
Postby richardmorris » 18 May, 2011 - 07:06
This is the one from the CX manual
Top
Re: LHM Leak - help
Postby Malcolm » 18 May, 2011 - 07:24
there u go Bobs you uncle dooo daahs your aunt,
Malcolm
Re: LHM Leak - help
Postby OldBill » 18 May, 2011 - 09:30
Thanks Malcolm that's very helpful.
oldbilll
sorry the drawing did not seem to come over
Des Smith wrote:Thanks, Tim, my post is a bit confusing, I guess.
AEP do the spheres for 18.50, but its the accumulator itself, which I assume is also known as the pressure regulator.
I presume that because it is an accumulator sphere that fits to it then the correct part description should indeed be 'accumulator' rather than pressure regulator?? I can find several references to it being called an accumulator on several other web articles in connection with other Citroen vehicles?
Des Smith
Post by Des Smith »
The garage think it might be able to re-condition it if there is a repair kit for it but suggested that given it's 21 years old, it might be a bit of a gamble and I'd probably be safer getting a new or professionally re-conditioned regulator.
Unless anyone has a spare lying around, I think I'll check with Martin at Pleiades and go from there.
Thanks for all the posts, guys.
Xsara Forte 1.4i 2000
Kawasaki GPz550A4 1987
Des Smith
Post by Des Smith »
Job done! :D
Martin at Pleiades has supplied a reconditioned regulator and all the spheres.
Des Smith wrote:Job done! :D
Happy Days!
Des Smith
Post by Des Smith »
Just picked up the St Tropez from the garage. She is now wearing new spheres all round and a new regulator. Currently parked in pride of place on an unsullied bit of tarmac, just to tempt fate. :D :lol: 8)
Very good indeedy.
