Sourcing a replacement accumulator
Des Smith
Post by Des Smith »
Anyone know where I can get the best deal on an accumulator for my St Tropez? My garage have got a Citroen quote of £232+VAT but if anyone knows a cheaper source, please could you let me know.
Also, would it be a good idea to change the accumulator sphere itself? It's got a slowish tick rate but just wondering whether to get it all done at the same time?
Xsara Forte 1.4i 2000
Kawasaki GPz550A4 1987
WHAT! As in the accumulator sphere? they are £25 from GSF! :shock:
Im sure someone on here will be happy to change it for you!
Des Smith
Post by Des Smith »
Thanks, Tim, my post is a bit confusing, I guess.
AEP do the spheres for 18.50, but its the accumulator itself, which I assume is also known as the pressure regulator. That's the pricey bit - Just found it on aep's ebay shop at £199. Is this the best deal I'm likely to get for a new one?
Are there recon ones around and how reliable will a secondhand one be???
Whats wrong with the old one Des?
Des Smith
Post by Des Smith »
The garage say it's leaking LHM. It's a niggling dribble rather than a major leak, but I want it sorted as its the last problem I have with the suspension & hydraulics.
I assume it can be re-conditioned but they won't want to bugger about with that and prefer to bolt a new one on.
Where's it leaking from? It's probably just the pipe seals which can be replaced at small expense but may just require tightening slightly.
Des Smith
Post by Des Smith »
Not sure where the leak is. I will ask, but they are usually pretty good about covering all the simpler fixes before replacing expensive bits.
Try pleides if your going to buy a new/recon.
Des Smith wrote:its the last problem I have with the suspension & hydraulics.
It won't be :lol:
if its leaking at the end of the mounting bracket view the thread from the CCC (citroen car club ) forum
http://www.citroencarclub.org.uk/drupal ... =19&t=6783
other wise give Martin at
Pleiades
Sawtry, Cambs
PE28 5SB
01487 831239
he is usualy very very helpfull,
he has an add in the Citronian CCC mag
Des Smith
Post by Des Smith »
It won't be :lol:
I meant this month :lol:
Thanks for the tip Malcolm. I'll do more digging tomorrow
Des Smith
Post by Des Smith »
citronut wrote:if its leaking at the end of the mounting bracket view the thread from the CCC (Citroën car club ) forum
Access denied, I'm afraid. :(
Anyway the garage will be giving me a full sitrep on the pressure regulator leak later today. While they've got it, I think I have them do all the spheres. They're not hard yet, but the ride is not as soft as the 16 and I reckon they are on the way out.
Well theres an easy way around that :wink: , or if you come to the National Des one of the raffle prizes is a years free membership!
Des Smith
Post by Des Smith »
£30 is almost two spheres! How much is the raffle???
£1 a strip
