Pipes with ends where there shouldn't be.
Way2go wrote:
KevR wrote:If I can't get the steel collar to fit, I use three cable ties instead and have never had a problem. Must be good quality though – I use some as used by the Post Office to close mail sacks and they're tough as old boots.
I always use the metal clips now either re-used or replacement since the MOT man objected to the Cable ties in earlier days and gave it as a reason for failure.
Over-zealous and probably uncalled for I agree but then again, why give them reasons to be strict on this.
Incidentally the rubber leak-off pipes are available more cheaply at GSF but are a false economy as the rubber is so crap they barely last from one MOT to the next!
Perfect solution?
http://www.beal.org.uk/index.php?search ... mit=Search
They look like they might be a good idea, don't suppose you've tried them Kevan? & what size would you need?
Defender110 wrote: Perfect solution?
Mmnh..........a good idea, but........
1) That doesn't look like a cheaper option than the real thing.
2) It will have to be cut off to remove to replace the pipes next time.
3) The real thing can be undone and re-used if you are careful.
:wink:
grecian
Post by grecian »
Whilst at my local garage yetserday someone came in who was an experienced mechanic doing work on a Modeo's brake pipes. The two guys at the garage had just been on an MoT update training session. From what they said it would be prudent to repair to original standard; you may find that cable ties on a pipe will be an MoT fail in future
previous- GS, Visa, 19DTR, 4x4, now ZX 1.9D and 1985 BMW M5
grecian wrote: From what they said it would be prudent to repair to original standard; you may find that cable ties on a pipe will be an MoT fail in future
And you would then have grounds for appeal, the magic word is ''secure'' and as cable ties meet BS5750 bla bla bla bla(or whay ever it is now) I don't see how they could call them insecure if secured with a cable tie?
Matthew; PM me your address and I'll pop some in the post for you mate.
rmattila
Post by rmattila »
Got a semi-mad idea and couldn't help but to try it out:
http://www.rmattila.com/images/remontit ... urn_union/
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
That looks fantastic :D Will it foul on anything on full lock?
1) That doesn't look like a cheaper option than the real thing. £4 for 25 is much cheaper
:wink:
Defender110 wrote:£4 for 25 is much cheaper
You are right. :oops: But in my defence you had to click through further pages to identify a quantity rather than a unit. 8)
Whoever did that 'repair' is clearly a bit of a gonad, seeing as they've formed a bend in the (solid) repair pipe. The bend moves as the suspension goes up and down, and that bend would have probably caused the sheer.
Wooscary
Post by Wooscary »
Kitch wrote:Whoever did that 'repair' is clearly a bit of a gonad, seeing as they've formed a bend in the (solid) repair pipe. The bend moves as the suspension goes up and down, and that bend would have probably caused the sheer.
I was thinking similar (though not from a knowledgeable standpoint). The two halves don't meet in a natural way. Weird.
KevR
Post by KevR »
rmattila wrote:Got a semi-mad idea and couldn't help but to try it out:
I'd been thinking of something along those lines, but didn't have the skills to make it - well done!
Curiously that is £1 more expensive than the local Cit Main Dealer. :?
Recent purchase price there is £11.61 ex vat and £13.93 inc vat. (As at Aug 2011)
Good to see they are still available from Citroen I thought they were no longer available. Are they shared with later citroen vehicles or are they just using up old stock?
