Mpg for bx16 carb
adamparis54321
Re: Mpg for bx16 carb
Hi
I have had a work mate look at choke for me , it opens up as it should when warm and the carb looks in good nick
shal i tinker with the carb ?
or would you do any other checks after the choke ?
2005 - 1990 Citroen BX14 St Tropez
2007 - 1992 Citroen BX17 TXD
2012 - 1991 Citroen BX16 Meteor
adamparis54321
the car is a manual 1.6 carb
adamparis54321 wrote:Hi
next would be make sure the timing is right then get the mixture set up on a gas analyser,
adamparis54321
Thanks Malcolm
I will let you know how I get on
Thanks for the advice
See ,I wanted a carb model because I didn't want all the fuss of Ecu's and crap like that,fine when everythings working as it should but a pita when they go wrong, my 406 has decided that once its warmed up it dosent want to idle evenly, revs go up and down ,sometimes it cuts out completely, changed the plugs and stepper valve also replaced the cat but its still doing it, this has been San awful three months for us with cars and it dosent look like its over yet...
i had a similar prob years ago on a pug 309 1,6 petrol was only doin 20 mpg and always smelt petroly and smelt like it was running rich, the plugs were removed and very sooty sign of rich mixture, this was a solex carb with auto choke, what is was causing the rich mixture was the waxstat that operates the auto choke was seized hence the car running on choke all the time even when warm, mite be worth checking this out, a good spray with wd40 solved the prob, new plugs and air filter jobs a gooden worth checking all breather hoses as well as these can crust up on the inside if yr engine has been running rich for some time
Dont forget Adam, it has a K+N panel filter so dont go changing it, It should last longer than the car, the plugs always looked sooty to me so I think Rutter could be onto something,
I replaced the oil breather thingy under the oil filler cap with a brand new one earlier this year so that should be ok,
Oh and have you discovered the led illuminated window switches yet
A very rare (almost unique) and desirable feature!Mickey taker wrote:Oh and have you discovered the led illuminated window switches yet
adamparis54321
hi
sounds stupid but what does the waxstat look like and did you pull it apart or just spray
sorry ,,, as you can see i am a salesman not a mechanic
adamparis54321
I have just spoke to the local citroen breakers in billericay
He has suggested a new carb
I will pop down Monday for him to have a look
Do you think a new carb will help revs and mpg ?
- x 25
Help?... From what I have heard from other's experiences, a new carb will transform it.
adamparis54321
Hi phil
Excellent , do you know the breakers in billericay ?
Sounded like they knew what they were on about
If he's got a weber that will fit it may be a better option than another solex,I would have thought that a second hand carb will only be better if its done less mileage that's why I never fitted the spare one that was in the boot ad I didn't know how much use it had had, another option would be to get the spare carb rebuilt
from what i can remember it looks like a solenoid which is fixed to the side of the carb and the plunger should move as the engine warms up (slowly opening the choke) i seem to remember 2 small water pipes connecting to the housing. it was a solex carb auto choke type 32/32?? but im goin back a few years.....mine was semi seized and sticking, a good spray with release agent wd40 or silicone lube done the trick with mine, im not sure how many different types of carb were fitted to the bx 16 so u may find some variants, good luckadamparis54321 wrote:hi
Theres a recon carb on ebay at the moment.
