Wanted: Rear Valance for a hatch.
Re: Wanted: Rear Valance for a hatch.
Doc wrote
I've done over a million miles in this one
Just another 139 million to go and you'll be arriving at Mars! :D
philhod
Post by philhod »
not sure which piece you mean here Doc. Is it the one that runs right across with the ends chamfered upwards?
If so it is very easy to fabricate and if you use Zintec, or a slightly thicker mat'l they last forevah 8)
67 and still rockin (but not in a chair)
Going for Pluto, Todd!
Phil, effectively it's the entire arse end of the car.. I have a photo somewhere...
Not the dash obviously, the bit behind it! This being the last new I had, which I cant really use, I think Dad would be rather upset if I cut it out of his car!
**WTF has happened to photobucket!? It's all gone mad!
philhod
Post by philhod »
:) Yeah Yeah! That's the piece. I have fabricated it from 3 pieces. the top bit with all the holes I cut from 1.5 mill and welded washers round the holes.
Cut the btm piece from the outriggers and made a new piece, fitted the 2 in place to make sure it all lined up then joined them with a strip that forms the upstand / shelf between them. Removed it all and stiffened the assembly and welded it inside only. Then painted the thing before re assembling and welding to position.
OK none standard, but it works and is cheap if you can't source one. The 3 I did are still around as far as I know. :P
I didn't fit a dashboard behind mine though :o
Post by RxBX »
Chris !
Have you looked @ the NT SHAWS 'BX Parts Clear-out' thread (which I also linked up in the recent Wtd. Rear Quarter Panel thread) ?
As I' notice they may have a couple available (If I've deciphered the list correctly) :?
From the BX Parts Clear-out Thread wrote:
Body structure
95630375 0 RH headlamp mounting panel 17.21 SOLD
95605366 1 Bonnet seal, above headlamp 4.28
95612062 1 LHR wing Mk2 saloon 177.26
95612063 1 RHR wing Mk2 saloon 177.26
95568456 2 Fuel filler flap 40.11ea
95631758 1 Front subframe Early 1.4 petrol 249.64
95563211 2 LHF wing Mk1 135.10ea
95563210 2 RHF wing Mk1 141.93ea
95619149 1 Front bumper Mk1 167.28
95587856 2 Rear panel assembly Saloon 138.63ea
95633140 1 Rear subframe Except 4x4 408.87
95563310 2 Front bulkhead cowl top 52.20ea
95631043 2 Front bumper side bracket 10.79ea
95645962 0 LHF inner arch panel 167.47 SOLD
95645961 1 RHF inner arch panel 104.49
95615414 4 LHF inner wing side panel 51.25ea
95615413 2 RHF inner wing side panel 43.65ea
95595027 1 LHF chassis leg 59.89
95595026 1 RHF chassis leg 111.84
95560885 1 LHF chassis leg end bracket 7.60
95560884 1 RHF chassis leg end bracket 5.50
95575083 1 Battery support bracket Except early 1.4 petrol 31.31
95587858 1 LHR lamp panel Saloon 41.20
95617022 1 RHR inner wheel arch assembly Saloon 163.66
95587860 1 LHR upper inner wheel arch Saloon 93.86
95567708 1 LHR floor leg Estate 22.58
95616854 1 Rear crossmember Estate 116.46
95616852 1 LHR towing eye Estate 31.11
95616853 1 RHR towing eye Estate 34.64
95615179 3 Lower front crossmember 51.54ea
95616626 2 Locking plate, front panel 15.35ea
If it is the correct item, you may need to get some overtime in ?
:lol:
ahh, blimey! I hadn't, but ta. Rather more than I paid for a new one from the dealer a few years back, but rarity has it's price! I'll give them a ring!
