Sorry Mat, I did see your photo and had a look, but I couldn't see any diesel coming out. That doesn't mean air isn't getting in though I guess (I'd like to be pessimistically hopeful here!), so maybe that should be my next port of call. I was going to ask what that funny white cross thing was for!mat_fenwick wrote:Apologies if you've already tried this, but did you see my photo above? If you haven't eliminated this as a possibility, try pumping the priming bulb while looking for leaks around the white thermostat valve. This allows diesel to flow through the heat exchanger passageways between the thermostat housing and filter during cold weather.
If it's leaking there when pumping, chances are the O ring behind needs replacing. I have an overhaul kit but rather would like to keep it on the shelf - I can give you the part no. or measure the relevant O ring for you if you need though?
EDIT - you mention plastic to plastic mating surfaces on the filter housing - there should be a rubber seal which fits around the rim of the filter, to seal between the lid and rim of the housing. If this is missing then that's likely to be the problem. Either way, you've successfully isolated it to the filter housing so that's a good start.
I'll have a look at that (hopefully on the weekend) and I might get back to you for a measurement of the O-ring, but unless mine is completely gone somehow then I should be able to match a new one to the old in there already.
Yes the rubber ring is there on the filter itself. I was talking about where the filter lid actually butts up to the rest of the housing - it's just two plastic surfaces. Maybe I'm imagining it wrong, but I thought the plastic of the lid seals to the plastic of the housing to stop air getting in/clean fuel getting out, and that the rubber ring seal is there more to stop dirty fuel mixing with clean fuel?
EDIT: Just wanted to say thanks to everyone for their suggestions! I wouldn't have got this far without all your advice for the fault finding! Boy I hope this is just an o-ring that needs changing
