They're still out there!
- x 25
- x 94
I can confirm that this one has been upt north for some time, previous owner had it for about 3 years.
It seems like he may have been telling the truth, so far I've only found the handbrake cables to be US and the o/s droplink. The rear tyres are a bit low so I'll do a swap with the fronts and put some better ones on the front.
Awaiting the arrival of new timing belt, antifreeze and LHM, if they dont arrive tomorrow, it's out with the wet vac and shampoo all the interior.
I've changed the oil & filter, air filter and fitted new pump belt, new alt belt to fit along with timing belt. The front brakes are now serviced with handbrake adjusted up.
Once the cambelt's done, I'll turn it round and have a look at the rear arm bearings and brakes.
Hopefully should be in for MOT before the end of the month.
Ian_Fearn
I was telling somebody at work today about how cheaply you can buy and run a BX.
Just to very quickly tot that lot up though at a specialist would (i guess) run at something like:
Cambelt, HP Pump belt, Alternator belt £200
Rear arm bearings £100/side so £200
Drop links £50
Discs and pads £150
2 new tyres £60
Handbrake cable £40
Add in a basic oil and filter change plus an air filter and you're looking at around 800quid at a garage.
Doing it yourself though:
Cambelt etc £35
Rear arm bearings £50
Drop link £25
Discs and pads £35
Tyres still £60
Handbrake cable £15
Plus oil and filter and you're looking at around 220quid. BARGAIN for a full on BX midlife crisis.
Drop links £50
Discs and pads £150
2 new tyres £60
Handbrake cable £40
Cambelt etc £35
Drop link £25
Discs and pads £35
Tyres still £60
Handbrake cable £15
Over and out from me
tim leech
- Our Trim Guru
- Our Trim Guru
And, thinking more along the "still out there" lines of course there's my new acquisition (free red TZD turbo estate). Apart from diesel money to collect and new plates, it has cost the following to put a new ticket (and shine on) on:
T-cut, stockingette and polishing sundries - £10
Front Brakes - swap from old car - £0
Brake pipe - from spares stock - £0
Accelerator cable (Tom's stock) - £0
Number plate and other bulbs from sale stock - £0
Welding - (though I'll do some more myself) - £105
Tom's time and elbow-grease - priceless.....
Possible future costs :
accumulator (seen the Eurocarparts option)
Waxoyl to treat underside after removing remaining traces of Welsh mountain track and paddock.
Possibly a rev counter sender (if the original isn't just mispositioned)
Now if I could just call in the Channel4 cleaning team to dispose of the German Shepherd hair all over the interior, I'd be well away.
tom
- Citroen Sorceror
Barnsley BXer
Might have found out tonight why the previous owner was so willing to scrap this car.
No panel lights.
Last time he'd had the panel out, he'd managed to break almost every possible bit of plastic under there, including the speedo cable.
Well I was fitting new cables anyway.
so now it had a full set of working panel lights and everything is screwed back as it should be.
No panel lights.
Not had the best day today.
As suspected the car had a dodgy o/s rear arm bearing. Luckily a good replacement was in stock. Both rear discs were shot (why do they always suffer on the backface) as were the pads.
I had some used discs and pads so I thought I'd be able to finish the job today. However the n/s also has a knackered wheel bearing.
So jigger it. first thing tomorrow I'm on the phone for some new pads and discs and new bearing.
Barnsley BXer
