wanted clutch
Cambelt is a bit fiddly but not as difficult as it sounds. There is no need to remove the crank pulley - take off the bottom bit of plastic - 2 small bolts and you can wiggle the belt through without creasing it excessively. Finding the hole in the crankcase is more fun - someone suggested a junior hacksaw frame which worked well for me.
