wanted clutch
wanted clutch
wanted clutch for 1769cc tzd turbo 1992 new or used can anyone help
- docchevron
GSF's probably your best bet, you'll get a Valeo unit and they are good.
I wouldn't even contemplate fitting a second hand clutch, it's a big enough job to do once and forget about it for a few years....
Chris G
Chris G
I agree, If the box is coming out then a full clutch is the only way to go, after you have done the job you definitely will not be in a hurry to do it again, the last one I bought was about £65 for the full kit, dont waste money on remanufactured ones, I have seen them fail prematurely.
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
£65 for a clutch kit thats not bad my local ces wanted £109 this is the first time i have fitted a clutch on a bx i have done a ford transit before but it was a easy job easy to get to with my bx i have just stated to do the work ive moved the drive shaft out of the way with it still atached to the hub as i did not have a 35/6 to undo from the hub moved pipes ect power steering pump and hydraulic pump looks a challenge with all them pipes
- DavidRutherford
- BX Digit man!
- docchevron
Re: clutch
I don`t see that being a big problemdonna wrote:i will have a think to take the whole lot out its geting hold of a engine hoist
Vauxhall apologist.
clutch
well i will start again tomorrow on the hurricane after i have moved the snow i think i will do the clutch first then the cam belt with engine in just had a look at doing the cam belt theres not much room to get your hands in could be a lot of swearing isit better to take of the road wheel first to get at the crank
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Wa? Je..Tsk...cavmad wrote:/\ He`s a creep you know.
I certainly wouldn`t bother with a second hand one either, might go again in a very short space of time. It`s probably worth changing the octopus at the same time as this is much easier with engine out and another job that`ll last a few years.
