gearbox
donna
gearbox
also the plastic that drives the speedo also has gearbox oil on it to i have just had a close look at the gearbox were the cast is broken and there is a groved hole were oil passes to lub the speedo hence oil on the plastic
ellevie
- Forum Treasurer
ellevie
- Forum Treasurer
Thanks Gaz. I was toying with the idea of buying the low mileage BX19RD that was going for £50 in Fareham which had a knackered clutch, so I would have had to have a go at changing the clutch --- It sounds like a pretty horrendous job.
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
BX19TXD 150k K Reg
donna
gearbox
its not that bad of a job once you have moved the drive shaft out of the way got pipes wires out of the way once the gearbox bolts are out it splits apart ok the thing is i was talking to my mate for a while and the jack sliped witch may have caused the problem as the box droped
ellevie
- Forum Treasurer
