gearbox
donna
gearbox
i have removed the gearbox from my hurricane to change the clutch and have broken a pice of cast of the gearbox were the o/s drive shaft goes in will this cause a problem i do have pics to show but dont how to send on the forum regards gaz
- BX Digit man!
BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
If it's the bit I'm thinking of I may have a spare....
If it's cos you didn't have a 35mm socket to take the driveshaft out I can post you one but it may be worthwhile buying one anyway when considering post costs
ellevie
- Forum Treasurer
Go to www.photobucket.com and register for FREE.
Follow their instructions to upload your pictures from your computer.
Click on the "post reply" button on this BXclub thread.
Copy the link to your picture by clicking on the "IMG Code" link under your picture in Photobucket.
Paste the link into your reply.
Check that it works ok by clicking "preview".
Hope this helps,
Hope this helps,
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
BX19TXD 150k K Reg
- BX Digit man!
Re: gearbox
donna wrote:i have some pictures of the damage how do i send them on the forum?
The instructions given by ellevie above are all over the forum in various places.I wrote:If you can host the image somewhere, and then post a link.
I have received an email with two photo's attached. If they don't appear on the forum, I'll host them myself and display them, but having seen them I can say for sure that the diff side-gear is fooked. Completely. Two functional surfaces are now missing, and it would leak oil as fast as you can pour it in.
Does beg the question as to how on earth you managed to do break it, given that the offside driveshaft practically falls out of the diff.
- BX Digit man!
Mr B
- Northern Moderator
- x 25
RichardW
That gearbox is cattle trucked... that's half the drive dog for the speedo broken off. It also looks to me like all 3 bolts for the shaft output / speedo housing are sheared off flush with the box, but maybe that's just a trick of the light. New diff required at the very least... Bad luck!
I NEED a BX TD.
- BX Digit man!
RichardW
Yes, it will probably drive, but it's almost certainly out of balance, quite possibly bent, and the bearing is probably toast. Not clear from the pics, but it looks like the seal face for the O-ring is damaged too, so I would expect it to leak oil. I'd take up CavMad's offer of a replacement 'box.
One other thought - what do the splines on the end of the shaft look like now.....
I NEED a BX TD.
