Dead battery? Or BXs coming alive and conspiring?
stuart_hedges wrote:the pattern seems to be that the car starts fine in the mornings but is a bit more reluctant when it's hot.
and then also wrote:Drove to Canterbury and back over two days - 90 miles each way. Each time I drove the distance in one and re-started the car once I'd arrived, just to see if it would work. No problems. Garn.
A while ago, I wrote: or a bit of heat soak into the starter making it a bit iffy. I've had a couple of starters that would work fine when cold, and fine when you'd not long stopped the engine. But there was a time period from about 20 mins after stopping to about an hour later when they would be a little tempremental, needing several twists of the key to make the solenoid go fully home, and hence energise the starter motor.
Sound familiar? Starts fine cold, and fine just after a run, but give it 20 mins, and nothing.
My guess is that the solenoid, it's pivot, or something to do with it is full of yuck. Strip, clean, rebuild. Cost: some smears of grease and some solder.
How did the house move go?
