Rear Arm Bearing Kits
Adrian (NZ)
Heya fellow Kiwispannerman wrote:Thanks guys, I will check out GSF if I have no luck here. Can you give me the SKF No for the bearing and seal,(not the kit NO) they may be available locally. Thanks Gerry
Guy I got my BX from up in Jaffaland worked for a Citreon Dealership, he had replaced the wheel bearing s on it so I am taking a guess that he got them quite easily in NZ although not cheap (as always).
Try giving Gary Keith Motors a ring up in Hamilton? They are pretty good got a good rep in the Waikato area.
spannerman
Hi Kiwi and Adrian, I will do some asking around next week and keep you informed . Adrian depending where you live, Kiwi's info may be helpful, but I will try my usual bearing supplier and see what they have.
Thanks everyone else, armed with the bearing & kit numbers makes it a lot easier to start the search.
Cheers Gerry
Cheers Gerry
AlanS
You'll find the SKF bearing number is 2400K or some derivative.
I had hells own job tracking them down until I was advised I had to use an authorised SKF dealer.
He denied all knowledge of being able to get car parts (as he is a power tool repairer) but once he tracked it down and it arrived, it had the word "Citroen" in very small print on the end of the box.
Just thought I'd mention that for when they start running you down all the dry gullies.
Alan S
Alan S
roscoe
For you folks in NZ, try Phil at AutoFrance in Manakau City, Auckland ([email protected]) - he seems to be able to get parts for most older Cits and is pretty knowledgeable on them.
cheers,
Roscoe
1991 TZD
2004 Peugeot 307
Roscoe
1991 TZD
2004 Peugeot 307
Just bought 4 kits from the following, quite a bit cheaper than everywhere else i had looked, & he is only charging me £4.50 p&p for all of em, bargain....
http://cgi.ebay.co.uk/Rear-Arm-Repair-K ... dZViewItem
- Our Trim Guru
Thats ironic, since the local GSF isn't the slightest bit interested in selling BX stuff anymore. Unless you want two year old "new" amtex spheres of courseDLM wrote:If you read the small print you'll find that this seller is a "trading arm" of Germs and Swedes....
spannerman
autofrance have them!!
Hi thanks Roscoe, Autofrance have them, but want $120.00 per side, so I will keep looking for a cheaper source.
Thanks Gerry
Thanks Gerry
roscoe
