Rear Arm Bearing Kits
I've had a look at the various posts in the past about peoples experiences of this BX quirk (ok pain in the ass), there appear to be various kit makes available. Can anyone advise which is the best one to get?
Also, is it wise to do both sides rather than just the one thats showing signs of leaning?
The most common kit appears to be the SKF kit that comes from GSF. Nothing wrong with it. I've now fitted seven or eight of them, and have yet to have a major problem.
If you do one side, then the chances are that the other side is past it's best, but I probably wouldn't bother doing it until it looks like it's actually on it's way.
Post by ken newbold »
Me too.
mnde
Meteor Man
Post by mnde »
I had SKF bearing kits fitted to both rear arms on my BX. The offside was creaking and had got an advisory at MOT time. The garage asked me if I wanted the passenger side doing at the same time - and I'm glad I said yes: once out, it was immediately apparent that the bearing was just starting to go.
Mark.
spannerman
Post by spannerman »
HI, HOW MUCH DO YOU GUYS HAVE TO PAY FOR A KIT (ONE SIDE) OVER THERE, i HAVN"T BEEN ABLE TO TRACK ONE DOWN OVERHERE YET.
CHEERS GERRY
spannerman
Ooops sorry didn"t mean to shout
Gerry
about £20-25 GBP
Our Trim Guru
x 13
Post by DLM »
But it's fairly heavy, which might add significant P & P to NZ - GS & F should be able to advise (or consult Alan S in Australia bout his experiences trying to get parts shipped to the Southern Hemisphere).
ellevie
Forum Treasurer
Post by ellevie »
SKF VKDA 23001 Rear Arm Bering Kit for BX
Bolt/Nut/Washer.....427g
Spacer ...................275g
Bearings x2............150g
Thrust Bushes x2.....80g
Seals x2...................25g
Dust Cover...............20g
Box ........................115g
Total......................1092g
box dimensions.....330x75x105 mm
The bolt, spacer, thrust bushes and possibly the dust cover should be reusable.
These parts make up almost 80% of the kit weight.
GSF and others do the bearings and seals separately.
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
spannerman
Thanks guys, I will check out GSF if I have no luck here. Can you give me the SKF No for the bearing and seal,(not the kit NO) they may be available locally. Thanks Gerry
Hmm, not quite as cheap as i was hoping for:
AEP Direct £28.74
GSF £29.38
Anyone know of anywhere cheaper, i need 4 of the little bleeders!!!
Brian
Post by Brian »
Bearing SKF BCAB 326332 B
Seal IELS 30x41x7x11
AlanS
Post by AlanS »
Depends a lot on how bad it is as to which stage of the kit you want to get.
Personally, I haven't bought a complete kit for years possibly because as soon as I hear the symptoms of an arm failing, I whip it out and replace it.
I have bought just the bearings on a couple of occasions from the local SKF authorised dealer (a guy who repairs power tools would you believe) and if everything else is OK that's by far the cheapest option.
Problems we have had have been outlandish freight costs which can double the cost on heavy bits quite easily, stuff getting misplaced by customs and the latest trick since we've adopted the yank 'scare the crap out of the populus as often as possible' policy, parcels more often than not opened and contents "confiscated" for any weak reason, usually something that someone in customs fancies. :roll:
In my case, I also have to pay GST on the combined charges for Parts, freight, Import duties and Customs handling (if applicable) so prices quoted invariably double.
I'd suggest trying this guy in Melbourne if you can't source them in NZ.
Caravelle Imports <caravelle AT hotkey.net.au> (AT replacing @ for obvious reasons) as I find he is as cheap as overseas and the parts he keeps are all first class as is his service.
Best way may be to see if you can get a set of second hand arms, strip and see what you want, order the bits and set them up so all you need to do is swap arms as a complete unit. That way, you know what bits you need for certain before you order the parts and may save you having the car off the road any longer than necessary.
Alan S
Unfortunately i dont have a reference point to tell me how bad they are, i can see them leaning out, but how bad, dunno?
MULLEY wrote: i need 4 of the little bleeders!!!
Two cars worth?
