Yup, but don't ask me how as I can't remember.tim leech wrote:Has anybody ever taken the the speedo binnacle out of a MK1
Oh....that's right...i do remember....you take the steering shroud off (including the little top cover) and under that are two screws on either side of the column. Once they are off you need to lift the top cover off the instrument cluster. Be careful as they break but are simply clipped in.
Lift it gently from the back (closest to the windscreen) where there are little vent grooves. It should unclip and more screws will be revealed (or something like that).
From memory you don't have to take the cluster out (but really can't remember), simply lift the top cover and see.
Michael
