Hi,
Do you still have the front bumper? Some kind soul re-shaped mine in a car park, and took the N/S trim off the bumper as well. My TZD is in white.
Also do you have the heater panel that has the switches mounted on it. My fan has stopped working and I it worked fine after I replaced the fan resistor a few weeks ago, so I'm assuming its the PC that has failed.
I may have to ask you to post/carrier them to me, as I'm on the Isle of Wight, and this time of the year, it costs an arm & a leg to escape.
Thanks
BX parts clear out
zebedee150
Barrie James
TZD Parts
Hi,
Sorry to hear about your bumper, I'll have to contact Edwards & Son in Billericay to see if they can help, unless someone else in the club has one available.
As regards the heater controls, the part I really need is the panel at the back of the switches which has the printed circuit on it. I know there is a 'fix' posted on the site, but I'm not sure my soldering is up to doing the recommended repair.
Let me know how much you want for it posted, and I'll arrange to get the money to you.
jwthwaites96
zebedee150
Hi Jw, Sorry for late reply. I have not been on the site for a few days! Not due up the M5 for a couple of weeks, but doubt that a rear suspension collapse is due to the swinging arm bearings. They tend to rust, crunch up a few bearing rollers and then the rear wheels adopt different angles! If the suspension cannot hold the weight it has to be in the fluid side of the system. If only on the one side it is more likely to be the seals in the suspension strut gone and returning the fluid to tank. You could always pull off the leak return pipe to the strut gaiter. If you get drowned its leaking !!!
Bx'less after 12 years
classicnut5
BX bits
Hi,have you a genuine stereo for the car(Blaupunkt and runs 6 speakers)?I would like to upgrade the 2 speaker system in mine,but keep the original Citroen-ness of the car.I would also like alloys and/or the little flaps that cover the valve on the wheel trims(must be grey).
Russ
Russ
