BX parts clear out
zebedee150
BX parts clear out
Having just picked up another TZD Turbo estate I seriously need to have a clearout.
I will be breaking my white estate, which has a full interior from a 1988 gti with one piece back seat, so if anyone needs parts let me know.
I can run them up to Birmingham w/end march 9th.
Also have an unused rebuilt Bosch pump and injectors for a normally aspirated 1.9 diesel for anyone wanting to run 'biofuel'.
Loads of other bits on the shelf let me know, could do with the space in exchange for small change!
Bx'less after 12 years
Brian King
- BX 4x4 Owner. Brave.
BX parts clear out
Have you got a front bumper?
zebedee150
surrey_man
Brian King
bx parts clearout
Thanks Zebedee. However i have just found out that Citroen still do brand new bx bumpers, and the cost is but a fraction of the painting. Since the accident has blown my ncb and excess anyway I might as well get my nose in the trough with everybody else and put in a claim. Thanks anyway.
- Our Trim Guru
andycadabra
jwthwaites96
- Our Trim Guru
Some DTR trim front seats from my old TZD available via the Doc if you're looking for something nearer to Brizzle. Virtually any BX front seat is compatible - and if it's just lower cushion wear you can swap that part in 2 minutes if you don't fancy twirling screwheads to swap the whole seat.
zebedee150
Hi there, Thanks for the interest. Car is still here, wife still nagging for me to get rid of it!
To answer a couple of questions.
Seats are dark blue Gti with the silver grey herringbone center panels. No door cards, wife did pitch those! Up in Weston in the next couple of weeks so close to Bristol. £10 a seat or £20 quid the lot!
Locks- Have a full set of matching door, ignition, etc, etc with two keys!
Pretty rare these days. £15
I think someone was looking for a turbo rad surround? Again small change and it's yours!
Zebedee, PM'd
Oh, forgot to mention that if its a non knackered turbo rad surround i'd be up for having that as well if its still available?
Just to double check, its the plastic which connects the top of the rad to the front of the car to stop it from wobbling about? about 3/4metre long?
zebedee150
Thats the one i need Jeff, as i'm trying to resurrect my TZD Turbo
, its not for the TXD....
