Not saying how to suck eggs because you probably have had the wheels off and looked anyways?
But if you aint are you sure its not just a faulty Brake Warning Light Cable? Lost count hte amount of time thought sod it new brakes when it was just the sensor.
Brake pads
stuart_hedges
Yes, it's been a bit of a marathon getting hold of parts! I'm not too worried for the moment - I'm still getting between 40-45mpg (apart from that tankful I mentioned on BXP, which included a grind through central London) so it can only be a little drip.docchevron1472 wrote:It's still doing that?
Blimus!
Er, you going to Stratford Stu?
If so I'll bring that pump off DLM's car.
I *think* David has now collected all the parts to convert it to a Bosch setup. Fun job for Stratford, maybe? 90% yes I'll be there.
Kiwi: I haven't had the wheels off yet, no. I live on a reasonably busy and very narrow street and I have no off-street parking. As a pair of pads only costs about £17 from GSF I bought them anyway - if I discover on Sunday, on mnde's nice, safe driveway, that it was just a sensor I'll keep them in stock. I will definitely need them some day!
As an aside, I once got pads fitted to the CX (no idea why I didn't do it myself). A while later I was under the car for some other reason, and noticed that the cables for the warning light were cut. Hm... I rather suspect I was charged for new pads, when the old ones were actually fine and the cables just got the snip.
stuart_hedges
Balls, balls, balls.
Finally, I'm home when it's not raining (don't worry, apart from the trip to Oxfordshire I haven't used the car at all) and got the wheels off for a quick look. Driver's side - absolutely fine. Loads of wear left.
Passenger side - not so much The inner pad isn't so bad, but the outer one has worn down to the sensor. I have a sticking caliper
demag
stuart_hedges
Ya reckon?
Last time I had this trouble, the garage insisted on a new caliper - on that occasion I'd had new pads fitted and they were destroyed within about 200 miles. It's obviously not that bad this time around - do they ever free off just by winding them back?
Don't forget I only have the roadside to work on and limited tools...
When Ken sorted out my caliper, he used some wd40 to get them moving & then used some grease to ensure they didnt seize again, not had any probs since. I think he may have even used a hammer to get them to move, they were stuck on that tight
That's very weird that
CitroXim
- Sir Jim of the Databases
Indeed it is. I've noticed over the years that both this and the FCF often play up a bit at 8PM. The FCF ran really slowly for a bit around 8.MULLEY wrote:That's very weird that
Why I don't know unless somethings else that runs on the host suddenly kicks into life at this time and eats up all the processing power.
Eastenders Fan Club forum perhaps?
Jim
stuart_hedges
