Newbie with TGS Athena
harryjoe
Yes found the code, it was under a load on gunk on that wing,
just been scrabbling about under the front.
Yes found it in all the books and paperwork that came with it,
Now !
There is a lot of play in the rod that connects the front wheels to the steering rack !, but a can;t feel any movement in anything else, so these are the track rob ends 'no', sorry, but i'm not very samiliar with names of parts in thius area, iv'e always got someone to do it for me
, looks like an easy repair, i did the track rod end on the XM then got it all tracked up agian.
Got to get it done, sounds like the front ends gunna fall off
Hi Phil
Thanks , it's not to bad is it, ! still keeping my eyes open for another Xm.
Still havn't got mine off my drive yet !
Now !
Hi Phil
1991 BX 1.6 TGS Athena 99k
1985 16 RD 164k Resting in the barn
1989 16 RD 189k Also Resting
1995 Clio 1.4 Auto 38k ( HER CAR )
2003 Scenic Privalage + 61k
electrokid
If the paint code and the logbook state different colours it's likely to be the logbook that's correct ! My paint code says it's Furio Red and the logbook says Venetian Red - and the car is Venetian Red.Yes found the code, it was under a load on gunk on that wing,
2002 C5 HDi SX estate
harryjoe
The paint code is ETNcR.
Not sure what the log book says, as iv'e only got the green section, 'n' it don't say it on that !,
Reg ; 11-06-1991
Orga no 5142 - December 7 1990
registered in Normacot , Stock on Trent. Ahhh Service record says Cobalt Blue. with a Citroen servive history up to 94k, now showing 99k, Cambelt changed at 88k.
Reg ; 11-06-1991
Linegeist
Hey Nigel - nice car!!! Good to see another Athena in the club!
Looking at the side-on pics, the bottom sill flange looks to be getting a bit corroded ......... I get the feeling a large can of hot Waxoyl shot around the underside and in the cavities might be a good idea before the great British idea of covering the roads with steel-eater kicks in this winter.
Beautiful looking motor though. Great stuff!
harryjoe
Hi Bob.
Thanks , yep, i will be sorting it all out before the winter, asap !!, as this will be my daily driver fora while till i find a replacement deisel Xm.
How many of these do you think there are left ? in this model then, it does seem they are a little rare !
As this is my first ever Bx, with two more still in a barn in sussex, 1 Mk1 & Mk2 both Rd's, the pics of these can be found on Sue Donym's posting on here, i must try to find the pics on the other laptop and post them on here agian !
I would imagine its MUCH less than 100, probably less than 50, so yup its a rare one and anice car to own thans to that interior, the 1.6 petrol is nippy and quite frugal if driven correctly.harryjoe wrote:Hi Bob.
electrokid
Well... confusion reigns etc
According to Harrap's the french for cobalt is.... cobalt. But the french for cobalt blue is cobalt d'outremer or bleu de cobalt, and outremer is french for ultramarine
There's
http://www.premierpaintpots.co.uk/Citro ... 0Codes.htm
and
http://color-online.glasurit.com/CCC/?language=8
neither of which mention cobalt blue or your paint code.
So pretty useless info there - we do try to help - honest !
I'd try to find a Citroën cobalt blue as a starting point - good luck.
There's
and
harryjoe
Thanks Mick,Susan Donym wrote:Well done Nigel,
I would have hosted the pictures for you , after all I have done most of them already
Getting cocky now with me note book
Where did you say Julies cars going to ????
harryjoe
electrokid wrote:Well... confusion reigns etc
According to Harrap's the french for cobalt is.... cobalt. But the french for cobalt blue is cobalt d'outremer or bleu de cobalt, and outremer is french for ultramarine![]()
There's
and
Thanks for that !
Hummm, looks like it could be a bit of a bugger to match up then,
That is definatly the code in the inner wing !
Ohh Bugger
Will have to look around 'n' get the nearest match then
harryjoe
Not quite 18 month'Susan Donym wrote:.......................................what started out as a bit of an April fools wind up ended up lasting 18 months although I know I was almost rumbled a couple of times ( too many medically trained people on this forum).
It was 11 month's when you were actually rumbled (Rather than almost) on the FCFforum (Pages 8 to 10 of the FCF thread)
So quite a few already knew you weren't a 'Sue' !
Also you don't need to be medically trained to rumble someone, as a good memory may be a better advantage.
Hi, Nigel and welcome to the BXC forum.
...... SUE DONYM'S...... posting of the barn BX'sharryjoe wrote:........... As this is my first ever Bx, with two more still in a barn in sussex, 1 Mk1 & Mk2 both Rd's, the pics of these can be found on Sue Donym's posting on here, i must try to find the pics on the other laptop and post them on here again !
